Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
    May 2013
    Huntiington Beach Ca
    Again you really need a lite loose hull with good set up to make these tuff little 2L sing. There's a lot of these blocks out there for cheap.
    If you can find a 1st gen 76-77 I think, the chest work is done. We modified the exhaust exit to match up to 1 piece plates.
    Have the cylinders checked and corrected. Find the correct heads and cut them to 26cc. Be careful torqueing the heads they tend to pull on the cylinders. Head studs may help? Most of the WH carbs will work just stay away from the small venturi 135 carbs. Get rid of the long tuner. 2.4 or Bobs works good. Raise the exhaust ports a little. 1.540 tends to work. Or find a 2nd gen block forget the exhaust chest work and do the same. Its a lot of work when you can find 2.4 but you can learn a lot grinding on these little motors.
  2. #17
    Your not going to pull those old two liters out of round..the 2.4's yes.
  3. Likes Merc 2.5 liked this post
  4. #18
    Minneapolis MN
    Quote Originally Posted by Baker343 View Post
    Would it be worth while to cut some off the stock tuner on a stock motor? Would I give up power anywhere? I have it all apart now and would be easy to slice a bit off before it goes together. Also considering taking a bit off the heads but I don't want to reach a point where I can't run pump gas. I plan to swap in new reeds for safety sake, but keeping the vertical front. I'll go to a 2.5 in the future and hang onto this for a back up, so I don't want to put a bunch in it.
  5. #19
    Just use a 200 tuner.
  6. Likes tnelsmn liked this post
  7. #20
    May 2013
    Quote Originally Posted by tnelsmn View Post
    If its for your Viking/175 2.0 I believe those tuners are different. If its the later tuner you can cut it some and even create a bell by splitting the end and rewelding. I saw you were a fabricator.
    If you keep your compression around 140 I think your safe to run 92 which Mn probably has not Priusville Cali 91 max at 3.50 a gallon and climbing. Thanks Beijing Biden.
    All the little things we did and you could do will help gain a small advantage.
    I saw you have a nice shop at Coon Rapids FD.
  8. #21
    Minneapolis MN
    Baker, Yes it's that same engine combo. I believe it's a '80. I am a metal fabricator and could do that. Not sure I want to invest the time and headache into that. I'm sure that casting thats been being covered in exhaust and oil for 30 years will weld like dog sh*t.
    Minnesota is trying desperately to be the California of the midwest. Governor is trying to force Cali vehicle emissions on us. Best gas I can get out of common pumps is non-oxy 91.
    Yes, being able to bring projects to work with me is a nice perk of the job. I prefer to be productive with my down time.
  9. #22
    May 2013
    Your Viking rebuild is truly impressive and not normally achievable by normal folk.
    You state your running a 80 175 2.0 on your Stream.
    Look at the stamp numbers on the block, if its a 80 175 I think its a 2.4
    Your effort to safe and restore that piece of family history is a labor of love and will provide endless performance and smiles.
    My shop is in Watts
  10. Thanks tnelsmn thanked for this post
  11. #23
    Minneapolis MN
    My shop is in Watts
    Thank you, it's a true labor of love. I can't find any numbers on the block. These are the only numbers I can find and they're on the head.
    Attached Thumbnails Attached Thumbnails IMG_5290.jpg   IMG_5289.jpg   IMG_5285.jpg
  12. #24
    82 or earlier. Lower cowl decal puts it 80-82.
  13. #25
    South Africa
    Make sure your big end bearings have metal cages, when you spool the motor beyond 6200rpm. Too many enthusiasts forget about this.
    Good luck,
    WolfgangB (South Africa)
  14. Likes Capt.Insane-o liked this post
  15. #26
    Sep 2017
    Ashland city tn
    Quote Originally Posted by wolfgangb View Post
    Good luck,
    Did the old motors even have plastic cages then?
  16. #27
    May 2016
    Upper Potomac River
    Quote Originally Posted by Merc 2.5 View Post
    I just took apart an 80' 200, had fat rods and metal caged rod bearings...
  17. #28
    Sep 2017
    Ashland city tn
    Quote Originally Posted by NoRdO View Post
    All my old 2.0 and 2.4 had metal , plastic cages come out with the 2.5 I thought. I know cranks have plastic cages but didn't think the rods did
  18. #29
    Minneapolis MN
    Lower main bearing.
  1. What should I do with this EE block? Porting and exh chest...
    By Kennay in forum Technical Discussion
    Last Post: 02-10-2020, 10:30 PM
  2. Mercury 2.5 245 260 Exhaust Chest Divider Plate Freshwater
    By mercstv in forum Misc. Parts and Accessories
    Last Post: 07-20-2018, 05:38 PM
  3. Looking for part number for a mercury 2.5 drag exhaust chest cover
    By superboattwin250 in forum Technical Discussion
    Last Post: 03-06-2017, 08:35 PM
  4. Wtb: mercury 2.5 280/300 exhaust chest cover
    By superboattwin250 in forum Parts Wanted
    Last Post: 02-23-2017, 07:54 PM
  5. Mercury 2.4 exhaust chest mods
    By coffeeguy in forum Technical Discussion
    Last Post: 10-27-2016, 06:33 AM
