Results 1 to 15 of 16
Thread: Warning module
    Aug 2020
    Maryville TN
    Warning module
    What's involved in adding a head over temp warning module on a promax 225? I recently purchased an xb2003 . I discovered that there is no warning module . It has the oil injection delete. The only temperature monitoring is a sensor on the top of the starboard head. One tan colored wire goes to the temperature gauge .The sensor works. The motor has a Brucato acu. Does anyone know if the acu supports those head temp sensors, at least I think that's what they are.
    Houston, TX
    The tan wire is temp sensor and goes straight to buzzer in harness. Not thru computer. It's hard wired. Same on carbs.
    Jan 2020
    Pinole, Ca
    You can add one on the other head and piggy back it on the same screw that the stbd head temp sender goes to...or you can put a readable sender in each of those head temp holes and run wires up to gauges in the dash if you wanna readout
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
    TX......somewhere?
    Quote Originally Posted by Rled View Post
    sensor on starboard head is all.. there is no over temp "module".. strictly a buzzer.. port head has a tan and/or tan blue thats for a TEMP gauge... same sensor tha ties inta tha ecu.. 2 tan/blks (ecu), 1 tan and/or tan/blue (temp gauge)...............
    Aug 2020
    Maryville TN
    Their is not a warning module.. There is no beep when I turn on the ignition switch. As far as I can tell, a tan wire goes to the temp gauge from the sensor on the top of the starboard side head. There is another tan wire that is not connected to anything. I was told that originally it was a 260 and the powehead changed to a 225 after the 260 blew up. I want to get all this corrected before boating season. I have a seloc manual but it is not much help.
    Jan 2020
    Pinole, Ca
    Sounds like someone disconnected it...that other tan wire should go to an idolator block and then into the 9 pin main engine harness...on up to the buzzer (somewhere near the key switch).
    TX......somewhere?
    you should see a small, plastic term block, starboard side where tha case halves meet that will have 2 tan or tan/blue wires terminated on it.. if you ground those two wires to tha block you should get a buzzer.. if not you need ta find out WHY... oiler stuff removed you will not have tha self check beeps when key is turned on.. test and/or trace tha tan wire on tha starboard head.. unless tha sensor has been changed it needs ta go to a buzzer and/or warning light.. thats its only function.. should be only 1 or 2 wires.. if 2 one will be black for ground other will be tan or tan blue... it will not read temperature... tha sensor in tha port head will have 2 tan/black going to ecu.. 1 tan or tan/blue that is for a temp. GAUGE only.. black ground
    TX......somewhere?
    Aug 2020
    Maryville TN
    Aug 2020
    Maryville TN
    I tested the starboard side sensor and got a beep. It only has one tan wire. The port side has three wires., Two tan with black stripe and one tan that is not hooked up to anything.
    The two tan/black goes to that acu harness. Where does the loose tan terminate?
    Attached Thumbnails Attached Thumbnails IMG_20210122_110519109.jpg   IMG_20210122_110506790.jpg
    TX......somewhere?
    ...............there is a tan in tha harness that continues up to tha dash/controller or gauge, if it has a gauge already...
  12. Thanks Rled thanked for this post
  13. #12
    Western Pennsylvania
    I have a 3 wire sensor from my 280 if interested, msg me
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
  14. #13
    Jul 2007
    Hamilton Ohio
    Interesting read. Was wondering as Merc mentions a visual warning kit (light) for over temp vs gauge. How does that function if wired into the current wiring, does it just go to ground at over temp settings ?
    Thx
    Gary
    Growing old is inevitable, growing up is optional.......
  15. #14
    Aug 2020
    Maryville TN
    I tested the sensor on the top ofClick image for larger version.
    starboard side head. It is connected to the temperature gauge. So it is registering water temperature. The sensors in the front of the heads read head temp. Am I thinking right?
  16. #15
    TX......somewhere?
    yes, you are... THAT type sensor IS for water temp.. tha other two are like explained...
  1. Warning Module
    By wallybobb in forum Outboard and Racing History
    Last Post: 10-12-2004, 11:27 AM
  2. Warning Module
    By RSM in forum Technical Discussion
    Last Post: 03-06-2004, 11:16 AM
