Results 1 to 5 of 5
Thread: Sportmaster/CLE question?
01-17-2021, 10:34 AM #1
I have heard that you can put sportmaster internals in a CLE case, is that true? Any modifications required?
Are the sportmaster parts more robust than the CLE parts?
Thanks Stoney
01-18-2021, 10:38 AM #2Member
- Feb 2015
- South Africa
- 91
- 7
- 10
- 19
Answers per sentence:
1) yes
2) no - but CLE single driveshaft top tapered roller bearing unloads, when pinion is loaded. Therefore SM has 2 bearings in X-configuration in that location. CLE casing cannot be modified to accommodate that arrangement. However, CLE driveshaft can be modified to accommodate the two-bearing arrangement for use in an SM casing (Mercury service bulletin).
3) I did not do any NDT on the components, but would assume material properties to be the same.
Summary - you are better off with an SM.
Rgds, Wolfgang (RSA)
01-18-2021, 11:27 AM #3Team Member
- Lake Coochiching, Ontario
- 7,756
- 272
- 485
- 1577
- 6 Post(s)
The Sportmaster prop shaft would be a lot newer. My old CLE prop shaft and a Hoss Triton are on the lake bottom
01-18-2021, 11:35 AM #4
Thanks for the explanation wolfgangb!!
I agree, I would be much better off with a sportmaster lower, they are getting hard to find in good shape thats why I was inquiring into the CLE.
I have a Merc chopper and a sportmaster shaft in the Intercoastal canal also, it was a small shaft!
Thanks!!
01-22-2021, 12:02 PM #5
I just put the sporty guts in a 4 bolt passage CLE, yeah everything swaps except the driveshaft is single bearing v. double bearing in the sporty.
1990 Collins Mirage - 15" 260
25 hp Merc with dry side pipe
stoneman liked this post
sportmaster vs cle question
By peedeerooster in forum Technical DiscussionReplies: 5Last Post: 02-14-2008, 11:21 AM -
Sportmaster Question
By Tony Montana in forum Technical DiscussionReplies: 9Last Post: 11-15-2006, 02:23 AM -
Sportmaster question
By EJP71 in forum Technical DiscussionReplies: 4Last Post: 09-21-2005, 10:53 PM -
Sportmaster Question...
By sosmerc in forum Technical DiscussionReplies: 0Last Post: 10-16-2004, 11:31 AM -
By PhastBoat in forum Technical DiscussionReplies: 8Last Post: 11-15-2002, 01:36 AM
