Results 1 to 5 of 5
01-10-2021, 04:32 PM #1
Coosa or Divinycell ??????????????
Hello all, I am replacing the floor in my STV RR it has a couple areas around where screws were used to hold down the seats and where the hinges for the race cowl were bolted down that are rotten. I am in the air about what material to use to replace the flooring. Im defiantly NOT using plywood and want to use a LIGHTWEIGHT composite. I looked up Coosa and Divinycell and both seem to be what im wanting I just dont know which one I should use ??? I know a lot of guys have replace their transoms with Coosa but I dont know about the flooring so any suggestions will be greatly appreciated thanks James
01-10-2021, 04:45 PM #2
I used coosa on the floor and stringers on the V21. Held up good .
01-10-2021, 04:45 PM #3Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
I used 1/2'' lower density coosa (12#) for my floor of my V-King. Glassed 1 lay of 1.5 oz mat over and under with 1708 glass tabbing all around the perimeter. I built glass bases for the seats. But also have bedded alum plate pcs into the coosa, and glassed over to drill and tap later for stuff. With the divinnycell (H-80) it would take 1708 glass on both sides of it and the pcs of foam are smaller so would have to be built on a table. Coosa is 4x8 feet sheets. Both are good matls. Weights would be very close to the same.
MattGreen liked this post
01-11-2021, 06:33 AM #4
I’ve read as many resto threads as I can. Coosa for floor, transom and stringers and diviny cel for core seems to be the ideal wood free program
XstreamVking liked this post
01-11-2021, 11:20 AM #55000 RPM
- Jan 2004
- Lindenhurst, NY
- 658
- 87
- 64
- 3359
- 267
I used Coosa 1/2" in the floor and transom of my Laser. It came out great and is easy to work with.
Vector Coosa and Divinycell questions.
By Farmer in forum Fiberglass and Composites DiscussionReplies: 26Last Post: 11-09-2018, 10:07 AM -
Divinycell vs balsa core
By LOSTINJ in forum Fiberglass and Composites DiscussionReplies: 14Last Post: 03-13-2018, 08:42 AM -
Divinycell Foam Core?
By tj309 in forum Fiberglass and Composites DiscussionReplies: 30Last Post: 10-03-2013, 04:53 PM -
Divinycell or Klegecell Dealers??
By 86ENTICER in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 10-22-2006, 04:20 AM -
divinycell for stringers
By 2shadow1 in forum Fiberglass and Composites DiscussionReplies: 6Last Post: 03-17-2005, 10:22 AM
