Results 1 to 3 of 3
Thread: Best way to fill drainplug hole
01-09-2021, 08:12 AM #1
I致e had to relocate the drainplug on my STV in order to mount a skid plate, so I知 trying to figure out the best way to fill the old plug hole as easiest as possible. I知 trying to avoid having to mess with mixing fiberglass with chopped fiber/cabosil,etc.
The skid plate will actually cover the hole but only just barely cover it, so I知 wondering if I should just put some 5200 or even 4200 on the plate and just use that to block it off?
Or is there some simple to use product out there that I can use to permanently fill it in?
Here are a couple of pictures showing the plug hole and the mounting tab of the skid plate that will cover the hole:
01-09-2021, 08:41 AM #25000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Trim that plate. That mounting ear won't miss a 1 inch hole.
ANTI40It's just an idea.
sonicss33 liked this post
01-09-2021, 08:50 AM #3
Question for the - to fill or not to fill the notch?
By Pachanga_rick in forum General Boating DiscussionReplies: 16Last Post: 04-09-2019, 02:12 PM -
Hardware hole fill for gelcoat spraying
By billykissell in forum Fiberglass and Composites DiscussionReplies: 6Last Post: 05-07-2015, 04:05 PM -
best way to fill hole in transom?
By rpm racing in forum Fiberglass and Composites DiscussionReplies: 5Last Post: 05-13-2005, 10:02 PM -
Best way to fill a old steering cable hole?
By skydog in forum General Boating DiscussionReplies: 10Last Post: 04-22-2003, 01:03 PM -
Hole to fill in a hole in transom?
By Jeff_S in forum Fiberglass and Composites DiscussionReplies: 6Last Post: 03-25-2003, 11:44 PM
