Results 1 to 3 of 3
    Aug 2017
    Grand Cayman
    Best way to fill drainplug hole
    I致e had to relocate the drainplug on my STV in order to mount a skid plate, so I知 trying to figure out the best way to fill the old plug hole as easiest as possible. I知 trying to avoid having to mess with mixing fiberglass with chopped fiber/cabosil,etc.
    The skid plate will actually cover the hole but only just barely cover it, so I知 wondering if I should just put some 5200 or even 4200 on the plate and just use that to block it off?
    Or is there some simple to use product out there that I can use to permanently fill it in?
    Here are a couple of pictures showing the plug hole and the mounting tab of the skid plate that will cover the hole:
    May 2016
    keys
    Trim that plate. That mounting ear won't miss a 1 inch hole.
    ANTI40​It's just an idea.
  3. Likes sonicss33 liked this post
    Aug 2017
    Grand Cayman
    Quote Originally Posted by Whaaaaat View Post
    Thanks, I thought of that, but too late, since by then I had already drilled a new hole, and I’ve already drilled the mounting holes for plate and powder coated it.
  1. Question for the - to fill or not to fill the notch?
    By Pachanga_rick in forum General Boating Discussion
    Last Post: 04-09-2019, 02:12 PM
  2. Hardware hole fill for gelcoat spraying
    By billykissell in forum Fiberglass and Composites Discussion
    Last Post: 05-07-2015, 04:05 PM
  3. best way to fill hole in transom?
    By rpm racing in forum Fiberglass and Composites Discussion
    Last Post: 05-13-2005, 10:02 PM
  4. Best way to fill a old steering cable hole?
    By skydog in forum General Boating Discussion
    Last Post: 04-22-2003, 01:03 PM
  5. Hole to fill in a hole in transom?
    By Jeff_S in forum Fiberglass and Composites Discussion
    Last Post: 03-25-2003, 11:44 PM
