Results 1 to 5 of 5
Thread: Long term Outboard Storage
01-05-2021, 10:58 AM #1Member
- May 2016
- Upper Potomac River
- 71
- 9
Hey Folks, is there any issue with storing an outboard upside down? Such as removing the cowlings and resting the motor directly on the flywheel? I have an old 115 tower that I took off of my viper, the lower has been removed and it has been in my shed upside down resting on the flywheel for about two years... Every once in a while I lay it down and spray oil in the carbs & plug holes and turn the motor over... I have a rag stuffed in the exhaust tube. Was just thinking all the weight of the motor is resting on the crank... good or bad?
01-05-2021, 04:40 PM #2
There should be no problem I see with that storage, the only reason I can fathom would be if you were spinning it upside down and it caused an uneven stress on the bearings, but I don't think that even that would be an issue because the crank bearings do not sit in tapered races that are designed to provide support in one direction only.
Short answer is no, shouldn't be an issue for the crank. Just be sure that nothing falls down the exhaust tube and personally I would not want my floats sitting upside-down especially in that motor where they have springs that would now be stored in compression...8' Yellow Jacket - 25 hp Mariner
1990 Collins Mirage - 15" 260
25 hp Merc with dry side pipe
tnelsmn liked this post
01-05-2021, 06:33 PM #3Member
- May 2016
- 71
- 9
Very good point about the float springs, didn't think about that... It was just the easiest way to store & move it in terms of space and not having a stand... Maybe I'll find a way to prop it up. It is nice having it upside down for moving with a hand truck when needed...
01-05-2021, 10:46 PM #46000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Few 2x4 and screws should make a reasonable stand
ground contact it self is corrosive
nothing should be hurt it’s just not really done often. Most I see get layed on the mount'06 Tracker All-Fish/Tournament V-18 90 Optimax, 46.8 gps Goal one complete reach 45 mph.
01-09-2021, 07:29 PM #5
Nothing wrong it that at all, I've done it a few times, properly winterized you will not have an issue.
15.5 cobra 175 hp merc - sold
18 tahiti tiger O/B 200 hp merc - sold
19 STV euro - 2.5 merc DRAG
Seebold F1 tunnel - 2.0 F1/champ
Prepping Merc Laser EFI powerhead for long term storage
By silverbullet02 in forum Technical DiscussionReplies: 1Last Post: 10-10-2010, 08:07 PM -
Long term storage
By Jamcat in forum Jet Boats, V-Drives and Stern DrivesReplies: 6Last Post: 04-29-2010, 09:47 AM -
long term storage
By bill mason in forum Technical DiscussionReplies: 3Last Post: 11-12-2002, 10:06 AM -
Getting a motor out of long term "storage"
By Wiski in forum Technical DiscussionReplies: 12Last Post: 07-15-2002, 12:07 PM
