Results 1 to 5 of 5
    May 2016
    Upper Potomac River
    Long term Outboard Storage
    Hey Folks, is there any issue with storing an outboard upside down? Such as removing the cowlings and resting the motor directly on the flywheel? I have an old 115 tower that I took off of my viper, the lower has been removed and it has been in my shed upside down resting on the flywheel for about two years... Every once in a while I lay it down and spray oil in the carbs & plug holes and turn the motor over... I have a rag stuffed in the exhaust tube. Was just thinking all the weight of the motor is resting on the crank... good or bad?
    Jan 2020
    Pinole, Ca
    There should be no problem I see with that storage, the only reason I can fathom would be if you were spinning it upside down and it caused an uneven stress on the bearings, but I don't think that even that would be an issue because the crank bearings do not sit in tapered races that are designed to provide support in one direction only.
    Short answer is no, shouldn't be an issue for the crank. Just be sure that nothing falls down the exhaust tube and personally I would not want my floats sitting upside-down especially in that motor where they have springs that would now be stored in compression...
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
  3. Likes tnelsmn liked this post
    May 2016
    Upper Potomac River
    Very good point about the float springs, didn't think about that... It was just the easiest way to store & move it in terms of space and not having a stand... Maybe I'll find a way to prop it up. It is nice having it upside down for moving with a hand truck when needed...
    Feb 2014
    Missouri
    Few 2x4 and screws should make a reasonable stand
    ground contact it self is corrosive
    nothing should be hurt it’s just not really done often. Most I see get layed on the mount
    Apr 2016
    Victoria bc canada
    Nothing wrong it that at all, I've done it a few times, properly winterized you will not have an issue.
    15.5 cobra 175 hp merc - sold
    18 tahiti tiger O/B 200 hp merc - sold
    19 STV euro - 2.5 merc DRAG
    Seebold F1 tunnel - 2.0 F1/champ
  1. Prepping Merc Laser EFI powerhead for long term storage
    By silverbullet02 in forum Technical Discussion
    Last Post: 10-10-2010, 08:07 PM
  2. Long term storage
    By Jamcat in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 04-29-2010, 09:47 AM
  3. long term storage
    By bill mason in forum Technical Discussion
    Last Post: 11-12-2002, 10:06 AM
  4. Getting a motor out of long term "storage"
    By Wiski in forum Technical Discussion
    Last Post: 07-15-2002, 12:07 PM
