Results 1 to 15 of 19
    how to remove bad core and delaminated fiberglass using pneumatic air hammer
    makes the demolition job go faster
    you'll need 15 amp power supply, compressor and the air hammer tool
    ...air chisel...
  5. Likes noli liked this post
    ...those plywood cores lasted more than enough years from day one, to serve the boat manufacturers purpose, warranty & costs in building a new boat... however they now decide to replace this core material, isn't going to last forever either...
  7. Likes noli liked this post
    That air hammer will crack the glass. I would NEVER do this on mine or anyone else's boat. Metal on glass is a big no-no.
  9. Likes Rigaud liked this post
    Calgary, Alberta
    A chainsaw circlet-style cutterhead (Lancelot and competitors) on an angle grinder absolutely eats wet (or dry) plywood, might be a better way and less chance of cracking as Xstream indicates.
    Matt
  11. Likes XstreamVking liked this post
  12. #8
    how would you remove delaminated glass as depicted in the video?
  13. #9
    I have used the lancelot chainsaw blade like described by mattgreen above. Aggressive 24# discs and plastic/wood wedges. When in the biz I built an air powered 18''chainsaw to cut out foam and wood quickly. jm2cts. Everyone does this stuff their way. Air chisels work for you go for it.
  14. Likes MattGreen liked this post
  15. #10
    I'm just trying to get as many experienced systems of removing delamination for educational purposes
    thanks for your input Xstream
  16. #11
    There is tool called a "gellcoat peeler" mainly designed for osmostic blister repairs. Some vids on you tube of it in action. It has some use as a grinder replacement.
  17. Likes noli, MattGreen liked this post
  18. #12
    Calgary, Alberta
    Hi Noli, to build on your thread, and a bit of a clarification, removing delaminated wood core is a somewhat different question than removing delaminated glass. Either or both can happen, for different reasons. Xstream is on the mark as usual with his input. Gelcoat peelers are for planing away Fiberglass laminates and gel. They have been on the market for decades and can remove lots of material, but not super accessible to DIYers. They are marketed to professional boatyards, I think a person wanting to fix their own boat would struggle to get access to one at a reasonable price.
    Another option for removing lots of Fiberglass at a time that is easier to get is a segmented diamond cutter head on a big angle grinder. These are marketed for bevelling and planing concrete. I have a 7” one on a 15 amp Makita grinder with an aftermarket cast aluminum guard/dust shroud. It absolutely mows down glass, like old stringer tabbing for example. A quick pass afterwards with 24/36 grit regular grinder disc and you’re good to go.
    Matt
  19. #13
    Thanks Matt for the input...would a gelcoat peeler work for the same task the guy in the video was doing [ time 0:30 to 0:40 ] ?
  20. #14
    looks like Metan Marine has been using air chisel for more than a decade
  21. #15
    Look closely at the 50 sec fwd mark. See the white marks on the green glass areas. That is where the chisel has fractured the glass. Look at the marks, same size as the chisel blade. They are in "get-er-done" mode. Not the way I did it, but if you want to make money it's the quickest way.
  22. Thanks noli thanked for this post
  1. How do you remove enamel paint from fiberglass?
    By bakerfreak in forum Appearance Mods
    Last Post: 04-24-2015, 04:57 PM
  2. Building materials/ Foam core/ Fiberglass/ Epoxy
    By Mhall222 in forum Parts Wanted
    Last Post: 09-07-2013, 02:49 PM
  3. Fiberglass and Core material suppliers near Melbourne, FL.?
    By Stitch King in forum Fiberglass and Composites Discussion
    Last Post: 12-06-2012, 04:02 PM
  4. Liberator Delaminated!!!
    By 78kona in forum General Boating Discussion
    Last Post: 09-29-2007, 06:05 AM
