Page 2 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 16 to 30 of 92
    Did that boat come from Michigan and had a 200 OMC on it?
    Does not sound anywhere close to 7500rpm, motor looks low.
  2. Likes Jimboat liked this post
  3. #17
    Aug 2017
    Grand Cayman
    Looks like the jackplate is mounted really low on the setback bracket too. That’s got to be dragging like hell in the water coming off the pad at speed. That’s probably acting like a built in “water brake” kinda thing. The first thing I would do is remount that as high as possible and maybe put a plate across the bottom of it running all the way to the transom to serve as a skid plate. That will probably help with planing too. The fact that it’s already adjusted to its maximum height also doesn’t allow you to raise the motor, which defeats the purpose of the jackplate anyhow.
  4. #18
    Dec 2013
    Columbus Ohio
    Yes the boat came from upper Michigan. Had a 225 Johnson on it. Should have left it on the boat.
  5. #19
    Dec 2013
    Columbus Ohio
    The video is where I had plates made to move the engine closer to the back of the boat which did lower it. I did move the engine up as high as I could. I was trying to move the center of gravity forward.
  6. #20
    Dec 2013
    Columbus Ohio
    The engine only RPMs between 6200 and 6500. That is with any prop so I know the props are not the problem. Looks like I need to put the engine back to where it was and mount it as high as possible.
    I moved it forward to change the center of gravity. It handled about the same with the motor back that is why I tried moving it forward.
  7. #21
    Dec 2013
    Columbus Ohio
    Yes way north. Had a 225 Johnson on it. Do you know any history on it? Thanks Ed
  8. #22
    Aug 2015
    Southeast
    Have you measured prop shaft height in relation to the hull? Get a 6 or 8 foot long straight edge of some sort and hold on the bottom of the boat sticking out towards the motor. Where is the prop shaft in relation? Prop shaft 1 inch above the straight edge would be a good starting point. Moving the motor in and out etc. probably has very little impact compared to the motor being too low. You may need to hang the motor on a hoist and remount using different holes on the bracket. Would be a good time to get the jack plate somewhat centered in it's up and down range. I've added and removed 12 inches of setback to a hull and it makes a difference but setback changes I don't believe are going to solve your problem. You've got a more fundamental issue in my opinion.
    disclosure, I'm assuming the center pad on your hull is even with or lower than the side sponsons for the 1 inch measurement.
    STV ProComp w/ 225 Promax
    STV Procomp with 280
    25 Liberator "The Battleship"
    Blazer 650 Pro Tour
  9. Likes Jimboat liked this post
  10. #23
    Feb 2014
    Missouri
    If you run 6200-6500 with 5” change in pitch your on a rev limiter as best guess.
    I mentioned wet just because I’ve seen so many I always ask.
  11. #24
    Dec 2013
    Columbus Ohio
    That was my first thought. Rev limiter set wrong. I sent it back and it was at 8000 I had them move it to 8250. I had Roy that built the motor check it and move it. Great guy should I send it back to Brucato encase something else might be wrong. Thanks Ed
  12. #25
    Dec 2013
    Columbus Ohio
    Yes that is what I did. A straight edge to the tip of the gear case. Made sure the jack plate was centered up and down so it would have the same amount of travel both directions. I also set the jack plate gauge at the half way mark on the gauge so we would know that was the bottom of the hull. The center is lower. Thanks Ed
    disclosure, I'm assuming the center pad on your hull is even with or lower than the side sponsons for the 1 inch measurement.[/QUOTE]
  13. #26
    If that is the one from the Oscoda area there is something wrong with the boat. Same gel scheme and trailer I remember, it was 12 -13 years ago and it was a very light lay up hull. Anyway PM sent.
  14. #27
    Jun 2020
    Man that motor is just struggling. My 21 Daytona with twins has 10" of setback, 1.5 above. Sorry to hear about your issues, my 260's scream.
  15. #28
    Its not the motor.
  16. #29
    May 2013
    Huntiington Beach Ca
ID:	480022Click image for larger version.
    I know your frustration. I have a 20' Baker Rampage which is similar to your boat that I bought minus engine to beat on as a Enduro boat.
    Its challenging to make a performance pleasure boat run north of 80mph with full interior, subfloor, carpet, saddle tanks, stereo stuff and a bow you can walk on.
    The first boat is purpus built lite layup race hull probably 500-600lbs. Mine was stripped of everything and came in at 850.
    Even though we both have to weigh 1350 without driver or fuel the lighter hull can postion his weight for better balance and CG.
    Try a 26p Trophy and test it and send it to Mark Croxon he is known to build fast bass boat props that can carry a load. Maybe try a wedge between motor and setback.
    Try testing with someone opposite of you in the rear seat. If you can remove rear decks, seats whatever is removable to lighten your load. test with lite fuel loads.
    Your porposing may be caused by not being able to carry the bow. You said you were able to run against the wind and carry the bow. You may not be able to compress or pack enough air to carry your bow.
    We are going to add pieces of wood to the top of our tunnels to try to compensate for our weight and test. Our boat came with 1" of squish in the tunnels. I have heard STV's have 2".
    Weight is a speed killer. In my option your LU should be even to slightly below until you figure out a decent safe setup. Hope this helps
    Also the white boat ran a stock 2.5 EE with a 28 chopper 1/2 below and ran low to mid 90's. We struggle to reach mid 80's and the boat ran wet with a ported 2.5 with LU 1/2" below
    IAttachment 480017Attachment 480018
  17. #30
    May 2013
    Quote Originally Posted by fasteddies69 View Post
    Why?
  1. 21 eliminator scorpion 86' drag prop
    By moosenelson225 in forum Props, Setup, and Rigging
    Last Post: 04-19-2015, 08:58 AM
  2. Eliminator Scorpion
    By Goose man in forum Hulls up to 20'
    Last Post: 04-28-2014, 01:03 AM
  3. Eliminator Sport Cruiser setup/prop question
    By Todd98SE in forum Props, Setup, and Rigging
    Last Post: 02-16-2014, 07:59 PM
  4. 300 HP Johnson Prop setup 21' Eliminator
    By CDignition in forum Technical Discussion
    Last Post: 06-15-2005, 04:42 PM
  5. 20' Eliminator scorpion
    By Bulletboy in forum General Boating Discussion
    Last Post: 10-07-2004, 12:14 AM
