Results 16 to 30 of 37
    Mar 2013
    Sunshine Coast, Queensland
    While I appreciate your advice, I really don't think it's because my engine is too low. If I lower it 1 hole, so the A/V plate is just on the surface, the spray actually stops. I am trying to get it up at least another inch, but without the spray. I am really starting to think my fairly blunt leading edge at lower trim angles being angled slightly forward going through the water is acting as a scoop. I will try fairing the blunt edge out and see what happens
  2. #17
    Aug 2015
    Southeast
    I think there's a communication breakdown here. Most on this site run their motor with the cav plate several inches out of the water. Just the bottom of the bullet in the water and the prop half surfaced. The original poster is running his closer to a normal set up with the cav plate at or near the surface which is several inches lower than a typical high performance set up.
    STV ProComp w/ 225 Promax
    STV Procomp with 280
    25 Liberator "The Battleship"
    Blazer 650 Pro Tour
  3. #18
    May 2016
    keys
    Not sure that is a "normal" set up. Maybe for a Carolina skiff or a barge. But there's no reason to have the motor that low. This guy is gonna try to reshape his lower rather than raise the motor 3 to 6 inches like it needs.
    ANTI40​It's just an idea.
  4. #19
    May 2016
    keys
    Your boat should not have the cavitation plate anywhere near the water at speed. It should be clearly high and dry. No amount of reshaping is going to fix this. But go ahead and try
  5. #20
    Mar 2013
    Quote Originally Posted by Whaaaaat View Post
    Mate, it's a social ski boat, not a high performance rig. "This guy" is not going to be raising the engine until it's 6" above. I am NOT talking about reshaping the lower, simply fairing the leading edge.
    Sorry my boat is obviously justa barge to you, and not as high performance as yours, it does what I want i just want to get the most of it I can.
  6. #21
    May 2016
    keys
    Quote Originally Posted by wettek View Post
    The best way to get the most out of your boat is to ask a question then ignore the most popular answer in favor of your own original logic.
    I never called your boat a barge, but your motor is mounted as deep as I would mount one on a barge or flat bottom boat. Have fun with the grinder
  7. #22
    Mar 2013
    No worries. I came here looking for advice. Obviously without seeing my boat or issue first hand you are able to instantly diagnose and rectify my issue for me, and what I am actually seeing is wrong. I don't want or need to raise my engine 3-6" and get the bullet on the surface, but I shouldn't be getting a spray like I am.
    I'll sort it out myself.
  8. #23
    May 2016
    keys
    You don't need to be surfaced. But your way to low. Your ventilation plate should be high and dry at planning speed. Your too low. Raise the motor until you loose water pressure or hole shot becomes unacceptable. And you'll be happier for it. Handling will improve. Efficiency will improve. Spray will disappear!!
    Or break out your grinder and reinvent the wheel
  9. #24
    Feb 2011
    HUDSON, FLORIDA
    wE lower the tilt, the bigger the spray. we dont know if he has a jack-plate.
  10. #25
    Mar 2013
    No, no jacking plate. As I said, lower the engine 1 hole and the spray stops, lift it one hole (and yes I have tried it 2 holes up using some extension plates), I get it. Kind of defies logic.
    I do appreciate the input guys, I just can't lift my engine more than about 2" (at which I still get spray) without introducing a raft of other issues (ski rope catching on engine etc), so I would really like to
    run with the A/V plate about an inch above the water line, but have my spray issue.
  11. #26
    May 2016
    keys
    What trim angle do you run when pulling or cruising?
  12. #27
    Mar 2013
    If I trim out to get rid of the spray at the height I would like to run my engine at, it puts a small rooster tail in the wake right at long line barefoot running position
    As you know, it's a trade off, engine up=better performance and efficiency but spray and rooster tail, engine lower=loss of performance and efficiency, no spray or rooster tail.
    Normally a bit more than halfway through the trim range gets rid of the spray, but starts the hump in the wake
    Trying to find the sweet spot
  13. #28
    Mar 2004
    Brooklyn Park, MN
    I am so confused by this whole thread. haha. It is a pleasure boat/ski boat, put that motor back down one hole and call it a day as you stated no spray at that height. I am guessing your motor has the standard water intakes on the sides of the lower and there is no water pressure gauge. Is the only issue the water spray? Do you need more speed for barefoot skiing or something?
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  14. #29
    Mar 2013
    Yes, I have a water pressure gauge and unless I want to foot at more than 60, I don't need more speed. I would just like to have my boat running as best it can, and the spray issue has become a bit of a challenge.
  15. #30
    Mar 2004
    Brooklyn Park, MN
    I just think you need to put that motor down as that is the solution to you problem (spray). Right now the water is being deflected up off the bullet, also you said when you tilt up you get a mini rooster tail, both you do not want for skiing. I am guessing mounting the motor lower, where there is no spray, does not really give you any ill handling characteristics. And if it does, I would think props would do more than motor height when the motor is bolted to the transom.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  16. Likes loop liked this post
  1. Leading edge
    By bigbluechevy454 in forum General Boating Discussion
    Last Post: 10-02-2012, 06:22 PM
  2. Thanx Leading Edge
    By Marko in forum General Boating Discussion
    Last Post: 06-16-2008, 11:19 AM
  3. thanks leading edge
    By rollin in forum General Boating Discussion
    Last Post: 10-04-2007, 09:18 PM
  4. Leading edge cup?
    By Carter Powell in forum Technical Discussion
    Last Post: 02-05-2006, 11:06 AM
  5. File leading edge of lower Unit?
    By Dregsz in forum Technical Discussion
    Last Post: 06-15-2005, 07:53 AM
