Results 1 to 13 of 13
Thread: Motor height on a 15' tunnel?
12-18-2020, 01:28 AM #1
I'm restoring an older 15' Hustler tunnel boat and am going to be installing a 1967 Johnson GT115 on it. It does have the standard racing gearcase on it and it is a short shaft. It's been 50+ years since I rigged my last race boat ( which was a 15' Hustler tunnel with an Evinrude X115 on it) but I can't remember what height it was. Where would be a good place to start? I want to be close because I need to know how high ( or low) to make the transom. Originally the boat has had a merc and an OMC that were both 20" shafts. Center of the propshaft even with the pads...up...down?
Hustler 15' Wildcat / Merc 80
Hustler 13' Wildcat / Merc 80
Hustler 13' Picklefork (Experimental) / Merc 80
Hustler 16' Victor / Evinrude 85
Hustler 15' Tunnel / Evinrude X115
Hustler 17' Lark / Suzuki 140
Ranger 17' Aztec / Merc 115
Hustler 16' Victor
Hustler 16' Victor / JohnRude 135 (current and restored)
Hustler 15' Family Tunnel / Johnson GT115 (current project)
Hustler 16' Victor
12-18-2020, 07:22 AM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Hee hee ....50 years ago we were kids and didn't know what we were doing and now we ask from kids that were like us.........The standard..... if there is anything as such would be 20 inches. The X115 was called a 17 inch I think.......Maybe telling installlers to go 2 inches higher......Might just use the V boat as a idea...... same boat company....All told when ya run it you will be adjusting it anyway....If.JMO...... I would leave theX115 on the Vboat..... as it's an piece of history....... Real neat find.
12-18-2020, 08:21 AM #3The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...installed height to where you know it will still get water to the intakes...adjust incrementally later...
Capt.Insane-o liked this post
12-20-2020, 07:45 AM #4Screaming And Flying!
- Mar 2003
- Belvidere IL, FARM
- 7,736
- 102
- 115
- 1556
- 514
Seen one of your boats running around my neck of the woods, had a 356 number on the side of it, beautiful boat.
God, Country, and Fast Boats
12-20-2020, 10:08 AM #5Hustler 15' Wildcat / Merc 80
Hustler 16' Victor
Hustler 16' Victor
12-20-2020, 12:53 PM #68000 RPM
- Feb 2007
- lily lake WI
- 3,206
- 57
- 1561
- 342
12-30-2020, 09:20 PM #7
Yea I have the same capabilities...just don't have a plug. I've thought about making one from scratch. Lot of work. Got the GT115 powerhead cleaned up, repainted, rerun and winterized. Now will remove from the boat for the winter. I want to prime and repaint the exterior while it's winter here. Where is Jeff Baker these days? He use to bore my cylinders when he was in Antioch.
Hustler 16' Victor
Hustler 16' Victor
01-01-2021, 01:39 PM #88000 RPM
- Feb 2007
- lily lake WI
- 3,206
- 57
- 1561
- 342
He works at Supreme marine in Minnesota plus he builds and still restores boats too there are 2 15' hustlers with the race capsule both in Rockford and both have your dad's number 356 on them one is competition orange the the one is black
01-02-2021, 01:54 AM #9
I know my dad ran 2 tunnels with the 356 number on them but they were both purple...one dark purple and the other lighter purple...the darker one I believe went to Wisconsin somewhere and the other I don't remember where it went...hell...I don't remember where my old black and white tunnel went...lol.
Hustler 16' Victor
Hustler 16' Victor
Michael J Giesler liked this post
08-03-2022, 04:44 AM #105000 RPM
- Aug 2011
- Antioch, il
- 251
- 37
- 15
- 108
DanUmbarger thanked for this post
08-03-2022, 08:42 AM #115000 RPM
- Jul 2021
- Pompano Beach
- 144
- 16
- 38
Put a jackplate on it, even if it's a manual one. Height depends on setback. I'd start 1" above the pad as a guess.
DanUmbarger thanked for this postslowJEEP liked this post
08-10-2022, 01:01 PM #12
If it's anything like a thundercat, I'd start an inch or two above the running surface.
08-10-2022, 01:44 PM #13
Will depend on boat weight and design. It'd be best to have a jack plate for easier adjustment, even with only minimum setback. if guessing, start with CL of bullet/propshaft even with pads or slightly above. should have water pressure gage to be sure you're getting sufficient cooling while testing higher settings.
12 ft rinker tunnel prop height help!
By spitfiremk46 in forum Props, Setup, and RiggingReplies: 1Last Post: 11-11-2014, 09:24 AM -
True Tunnel shaft height?????????
By duckrazee in forum Props, Setup, and RiggingReplies: 30Last Post: 08-20-2014, 08:43 AM -
engine height for true tunnel
By sheppie62 in forum Props, Setup, and RiggingReplies: 29Last Post: 08-13-2009, 08:39 PM -
Motor height on tunnel
By Carter Powell in forum Technical DiscussionReplies: 0Last Post: 06-17-2004, 09:50 PM -
engine height for tunnel hull
By mark Rasure in forum General Boating DiscussionReplies: 4Last Post: 01-24-2002, 10:31 PM
