Results 1 to 5 of 5
    Netherlands
    Mercury 300xs HT tuner + poppet valve diverter?
    Hello,
    Just orderd a hydrotec tuner for my Mercury 300xs I have already a DBR flash and lightweight flywheel and was looking for a tuner that helps a little above 6000 rpms (And offcouse the sound ) read good things about the Hydrotec and found 1 second hand never installed.
    My question:
    The package I orderd include also a poppet valve diverter. I am a little affraid that my mid section become to hot any expierence from people that went the same way? Will the paint go off or just more cleaning work? I will use my stock 20 inch mid section.
    Thanks
    Boat: Hydrostream virage
    Engine: Mercury 300 XS DBR 1.3
    Props: 32' performance drag4 ,buckshot gen2 4 blade cleaver 34'
    Max speed: 113mph
  2. Likes SH_BR liked this post
    Netherlands
    No experience with running poppet valve diverters on a 300xs?
    Max speed: 113mph
    Netherlands
    Just a update, it runs fine after 2 years no problems with heat on mid section or loosing paint ,mid range better and sounds like a beast. Installed both poppet valve diverter + Hydrotec exhaust tuner
    https://youtu.be/rPcvDkXF3EY
    Max speed: 113mph
  5. Likes David, mistah_max, SH_BR liked this post
    Jul 2009
    gatineau qc, canada
    do you find it a bit lazier on takeoff? when i switched from stock tuner to hydrotec on my 250xs a hesitation developped when trying to get on plane. i taught that maybe the shorter lenght of the tuner vs the full lenght I had now needs more exhaust pressure to ''fill'' the can and push it out the exhaust.
    I've since switched to a 300x and kept the tuner. seems to still have that hesitation on takeoff. and i need all 8 PVS holes open on trough hub props to get the prop to spool up and get on place.
    1998 charger stv. 225 promax. -sold-
    1993 22 talon. 2016 yamaha 200 SHO, nizpro tuned
    Netherlands
    Hi ,
    No for me it works little better with holeshot but I use small hub props and need to put throttle to the floor (small exhaust loose bottom end torque and gain hp high rpm). But mid range and higher rpms its a lot better for sure. Think through hub props its a way harder due to less exhaust gas
    Max speed: 113mph
  8. Likes SH_BR liked this post
  1. 300XS won't warm up. Poppet valve open? Or stats?
    By Sleek Jr in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 04-13-2017, 12:56 PM
  2. 300XS Poppet Diverter
    By 1122 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 06-09-2015, 07:41 PM
  3. question on POPPET VALVE 300xs
    By mercury01 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 07-05-2014, 02:10 AM
  4. MAD EFI Tuner & Simon popet diverter on 300XS?
    By MaDneSS in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 10-12-2012, 03:08 PM
  5. YAMI-poppet diverter/presure control valve
    By Dingie 2 in forum Technical Discussion
    Last Post: 09-28-2009, 10:07 PM
