Results 1 to 12 of 12
    Nov 2003
    Portsmouth VA
    Aluminum Trailer Refinish
    Does anyone have a good way to bring the finish back on an aluminum trailer that has aged? Not terribly corroded but been sitting outside for years.
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
    Jun 2018
    Floating around
    I used some Eagle One etching mag wheel cleaner and some scotchbrite pads to resurrect some badly oxidized aluminum. Looked like new when it was done. Gotta wash it all off with lots of fresh water and spray WD40 over it all to keep it from chalking up again. It took some time, but worked very well.
    I was thinking you would want "non-etching" cleaner?
    https://generalchem.com/product/auto...BoCTRMQAvD_BwE
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    In the detail industry it's called Briter or Aluminum Briter.
    Nov 2003
    Portsmouth VA
    Quote Originally Posted by TraceF3 View Post
    Trace, is this the stuff in the link in David's post above?
    Jun 2018
    Floating around
    the aluminum I was cleaning was very nasty. Etching cleaver was the only stuff that broke through
    Jan 2018
    Not a tourist in Forida anymore.
    I’d see what the local big rig shops are using. Semi's have tons of polished aluminum parts, and some of those drivers take a lot of pride in keeping their rigs shined up...
    that’s a reflection of the ceiling.
    Attached Thumbnails Attached Thumbnails E4E1EBC8-61CB-4F90-9767-086F87B2C0F6.jpg
    Dec 2017
    Quote Originally Posted by 99fxst99 View Post
    It's hard for me to know. The product was/is made by ProChem. They are a detail supply company. Works fast.
    Try this-
    Aluma Bright, Aluminum Cleaner and Brightener, 1 Gallon Concentrate: Amazon.com: Industrial & Scientific
    Sep 2017
    ontario
    Trace3 is correct - rigs and trailer shops just use aluminum briter, it is used as a wash- brush it on like you would use for a pale and truck brush - just like soap and water - rinse it off voila . Now the tarnished level of your unattended trailer may need more love but it works well and is super easy - may just be muratic acid and water not sure but works . Pay attention to the mix instructions they have it figured out . Easy peezy- good advice heed it
    Nov 2003
    Portsmouth VA
    Just ordered a gal, we'll see how it works.
    Thanks!
    #2 iron from the Mayo clinic, Fla. / Blue Ridge, VA.
    aluma bright is tha schit , just dont leave it on to long, I use a spray bottle , it will turn into a white foam and very soon after needs to be blasted off , I use a pressure washer , night and day with no effort , just spray on and blast off , even takes off grease , fun out
    I use it straight, no deluting , on polished surfaces like wheels n such it will dull the finish to bare metal is why I state don't leave it on to long. on a trailer that will not make a difference, just do sections at a time and dont let it dry
    most overnite successes usually take at least 10 years
    Certified turd polisher,
  12. #12
    Ft. Lauderdale, Fl
    Be careful if the trailer is anodized.... might need to dilute it...............
  1. Wtt nice aluminum Allison trailer for nice steel ally trailer
    By speedinstream in forum Tow Vehicles and Trailers
    Last Post: 08-17-2015, 02:08 PM
  2. Where to buy aluminum trailer?
    By fastcat in forum Tow Vehicles and Trailers
    Last Post: 03-22-2005, 10:18 PM
