Results 1 to 15 of 22
    Lake Coochiching, Ontario
    Smart craft 100 mph speedo
    Does Mercury make a 100 mph smartcraft speedo?
    Apr 2007
    Texas
    If you are talking about the units with the analog dial, LCD readout and three buttons at the bottom... I think those only went to 80mph. I think Livorsi makes a similar unit that goes to 100 and 120.
    Yes, I was hoping for an analog dial 100 mph. A Merc speedo would look better beside the Merc Monitor
    Feb 2006
    Formerly Central WI/LOTO Currently PHX AZ
    There used to be one that went to 120 but it was just a daisy-chained one, no LCD screen or buttons.
    I know it was offered in 5”, but I don’t remember if it was offered in 3-3/8”.
    A problem is only a problem when viewed as a problem...
    Oct 2018
    TX
    I'm having the same issue----I run a Bullet with a 250R and an 80 mph gauge isn't enough. I know for a fact Merc makes a Smartcraft 120 mph gauge but only has an analog dial (No digital readout). I verified this with Merc rep at the Classic Expo this past weekend. Dealers can't locate it in the parts manual and I failed to get the part number when I had the chance. I don't want to mix & match gauges with another company and I damn sure don't want to pay Lavorsi prices I was quoted for the complete set either!!
    Jan 2020
    Pinole, Ca
    3 3/8" (STANDARD) 120 mph smartcraft gauge, white. P/N 8M0069417
    It is the pigtail inline style, with no LCD, so it goes in line with your oil press./water press/voltage/all small gauges.
    May 2001
    great south bay
    What feeds it info? NMEA2k gps input?
    Jan 2020
    Pinole, Ca
    No, NMEA 0183 data or any smartcraft speedo input installed in the boat or engine.
    Sep 2017
    ontario
    I know there are a few exceptions on motors and Speedos as far as SmartC .
    David's application 200xs needs a paddle wheel to register - correct ?
    So do you need to go GPS on the above application other than paddle wheel which I believe was more of a trolling feature .
    May 2001
    great south bay
    Sounds like you have a bit of Smartcraft Knowledge....
    I have a mercmonitor gauge and need to find the cable to tie it into the blue can wire, Gauge has 14 pin plug and blue can wire has 10 pin
    I found 2 part numbers
    84-8M0055042
    84 8M0055076
    I know there are different level gauges and some have NMEA2k gps antennas and other sensor inputs
    I am going to use the small digital speedometer on my Merc Monitor and if I hate it I will replace the tach with a GPS speedo. Not Merc as I want black face white needle
  12. Likes 25two.stroke liked this post
  13. #12
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by 2.5-21 View Post
    84-8M0055042
    84 8M0055076
    Post a picture of the back of the gauge...I have never seen a 14 pin connector on the back of the gauge.
    And...are you plugging the stand-alone "blue cable" right into the gauge, or do you have a junction box and need a drop cable from the gauge to the junction box?
    Moreover, what other gauges are you trying to run with the mercmonitor?
  14. #13
    Jan 2020
    Pinole, Ca
    84-8M0055042
    84 8M0055076
    The first number you listed: 84-8M0055042 Is the drop harness for a mercmonitor that includes a NMEA 2000 input/output to go directly into a NEMA backbone rather than into a junction box and a NMEA Gateway.
    If your gauge, however, has a 14 pin (round connector) on the back then neither of those harnesses would work. And, I also would have never seen that connection aside from an engine harness. I would have to do some digging to find a 14 pin gauge harness...if it even exists. But if merc made the gauge then they made the harness, but they take stuff out of the accessory book, so they don't list the p/n and descriptions for all the stuff they make.
  15. #14
    May 2001
    great south bay
    Jan 2020
    Pinole, Ca
    That looks like you need the vessel view harness. 14 pin into the gauge and 10 into a junction box.
    p/n
    84-8M0075065
    Then if you want to go from a blue cable to the gauge with no junction box then you would have to get a male to male p/n
    892452T01
    But I would not really recommend that, its kinda ghetto.
  1. Mercury Tech: How to upgrade to smart craft?
    By altamate in forum Technical Discussion
    Last Post: 02-09-2017, 03:48 PM
