Results 1 to 12 of 12
12-05-2020, 12:03 PM #15000 RPM
- Mar 2020
- netherlands
- 163
- 14
How does an external fuel pump work
Hello, im looking to buy an merc xr2, and it has an external fuel pump. I was wondering, how does this work.
I assume you have a switch in your dashboard to turn it on, and then you start your engine, and then leave the fuelpump on?
Does it regulate the fuel? What if the engine is off but the fuel pump is on? Will it just build pressure? And what about different RPMs? The engine needs more fuel at high rpm then at low rpm.
How does the external fuel pump does this?
12-05-2020, 12:20 PM #2
rock liked this post
12-05-2020, 02:22 PM #35000 RPM
- Mar 2020
- netherlands
- 163
- 14
So does the fuel pump turn off when the max pressure is reached? What happens if i have te fuel pump on and the engine off?
12-05-2020, 02:28 PM #4
Feed the pump with the key on wire. Use a relay and trip it with the purple wire.
RockTeam Junk
12-05-2020, 02:53 PM #5
Pump runs continuously. If the pump is on and the motor is off... it will run until it kills the battery and/or flood the carburated motor if the needles & seats leak at all.
12-05-2020, 03:44 PM #65000 RPM
- Mar 2020
- netherlands
- 163
- 14
12-05-2020, 03:55 PM #7
They are not positive displacement pumps I think max pressure is like 7 or 10 psi, they just kind of cavatate and stop moving fuel (more like a leaf blower than an air compressor)... but why do you want to leave the pump running when he engine is off????
12-05-2020, 06:38 PM #8
It all depends on if your mota is carburetor or fuel injection. Your is probly carburetor and will need a low pressure pump. Such as a Holley RED.. Red is made for carbs and put out about 4lbs. No return line needed.
12-06-2020, 05:56 AM #95000 RPM
- Mar 2020
- netherlands
- 163
- 14
Thanks! Because i wont switch it with ignition key but ecternal switch. So i might forget to turn it off
12-06-2020, 09:19 AM #10
Turn it off with the key,im sure you won't forget to turn the motor off. like you would turn off your car it has an electric fuel pump.
David - WI liked this post
12-06-2020, 11:07 AM #11
12-06-2020, 11:12 AM #12
keefallan, David - WI liked this post
External fuel pump/regulator
By fliyingfinn in forum Technical DiscussionReplies: 5Last Post: 02-02-2012, 12:45 AM -
external fuel pump......
By Gorilla0178 in forum Technical DiscussionReplies: 8Last Post: 03-02-2011, 08:56 AM -
300X Fuel Filter / External Pump???
By at100plus in forum Technical DiscussionReplies: 14Last Post: 04-20-2007, 11:04 AM -
Wiring external fuel pump??
By Liquid Force in forum Technical DiscussionReplies: 10Last Post: 12-12-2006, 12:46 PM
