Results 1 to 9 of 9
    Mar 2009
    Saint Lucie Florida
    ISO: SST60 props in 12-12.5 x 22,24 size range
    ISO: SST60 props in 12-12.5 x 22,24 size ranges looking for some cleavers, semi cleaver and choppers that are 13 spline in that size range, pm me with what you have.
    Jan 2020
    Pinole, Ca
    I have a prop that has been sitting on the shelf for years...It is painted black but it is stainless and it is brand new: never been run. Its stamped SST in big ass letters on the hub. 22 pitch I believe. I know little about Johnson splines/dia so if you could give some specs that would be great. what hub dia. is the SST60, how many splines does it have, and are they the squared off splines or the sharp triangle ones?
    I believe the prop I have has some super sharp triangle splines. I'll post a picture today or tomorrow.
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
  3. Likes TwzteD liked this post
    Mar 2009
    Saint Lucie Florida
    Jan 2008
    redding cal
    sst60 prop
    Quote Originally Posted by TwzteD View Post
    have a titus built 22.5 pitch ran on sst60. like new .will send picks if interested. greg
  6. Likes TwzteD liked this post
    Mar 2009
    Saint Lucie Florida
    Quote Originally Posted by ggoslow889 View Post
    send me some pics, and price.
    Jan 2020
    Pinole, Ca
    Hey the SST I have is only 17 pitch...but it is brand new. So it would have to be worked to make it worth your while buying it. Its got some killer rake to it. I'll post some pics tomorrow, I left my phone at the shop today after I took some pics. Let me know if you would even want to bother with one that low of pitch...I'd make you a good deal because you need to have it worked.
    Jan 2020
    Pinole, Ca
ID:	478618Click image for larger version.
ID:	478619 Definitely would have to be cut for your application, but it is brand new.
    Mar 2009
    Saint Lucie Florida
    Thank you for the pictures, I thought you had a cleaver or a chopper
    for an sst60 (race engine)
    Jan 2008
    redding cal
    sst prop
    give me a call 5302096661. will send pick to you. 350. plus ride 12 3/8--22. made for sst 60 drag set up. have 12 passes on prop. thanks greg
  1. 3 blade exhaust thru props for 4 inch hub gear case in 28-30 pitch range
    By jdgearheadford in forum Props, Setup, and Rigging
    Last Post: 07-03-2015, 11:28 AM
  2. Gearcase Size 2003 Merc 110hp 4stroke- Will the props swap?????
    By cturboaddict in forum Props, Setup, and Rigging
    Last Post: 04-16-2013, 07:12 AM
  3. Looking For SST60 Props?
    By adrenaline john in forum Racer's Hangout
    Last Post: 02-19-2008, 12:22 PM
  4. I buying a couple props. what size 14 3/4 or 15??
    By aircraftman in forum Technical Discussion
    Last Post: 07-17-2003, 07:51 AM
  5. OMC mid-range air bleed size???
    By jasonyb in forum Technical Discussion
    Last Post: 02-19-2003, 07:05 AM
