Results 1 to 9 of 9
12-04-2020, 06:37 AM #1
ISO: SST60 props in 12-12.5 x 22,24 size range
ISO: SST60 props in 12-12.5 x 22,24 size ranges looking for some cleavers, semi cleaver and choppers that are 13 spline in that size range, pm me with what you have.
12-04-2020, 12:03 PM #2
I have a prop that has been sitting on the shelf for years...It is painted black but it is stainless and it is brand new: never been run. Its stamped SST in big ass letters on the hub. 22 pitch I believe. I know little about Johnson splines/dia so if you could give some specs that would be great. what hub dia. is the SST60, how many splines does it have, and are they the squared off splines or the sharp triangle ones?
I believe the prop I have has some super sharp triangle splines. I'll post a picture today or tomorrow.8' Yellow Jacket - 25 hp Mariner
1990 Collins Mirage - 15" 260
25 hp Merc with dry side pipe
TwzteD liked this post
12-04-2020, 12:12 PM #3
PM me pictures and a price please
12-04-2020, 05:09 PM #45000 RPM
- Jan 2008
- redding cal
- 114
12-05-2020, 08:08 AM #5
12-05-2020, 10:37 PM #6
Hey the SST I have is only 17 pitch...but it is brand new. So it would have to be worked to make it worth your while buying it. Its got some killer rake to it. I'll post some pics tomorrow, I left my phone at the shop today after I took some pics. Let me know if you would even want to bother with one that low of pitch...I'd make you a good deal because you need to have it worked.
12-07-2020, 11:51 AM #78' Yellow Jacket - 25 hp Mariner
12-08-2020, 06:57 AM #8
12-09-2020, 11:53 AM #95000 RPM
- Jan 2008
- redding cal
- 114
3 blade exhaust thru props for 4 inch hub gear case in 28-30 pitch range
By jdgearheadford in forum Props, Setup, and RiggingReplies: 16Last Post: 07-03-2015, 11:28 AM -
Gearcase Size 2003 Merc 110hp 4stroke- Will the props swap?????
By cturboaddict in forum Props, Setup, and RiggingReplies: 0Last Post: 04-16-2013, 07:12 AM -
Looking For SST60 Props?
By adrenaline john in forum Racer's HangoutReplies: 3Last Post: 02-19-2008, 12:22 PM -
I buying a couple props. what size 14 3/4 or 15??
By aircraftman in forum Technical DiscussionReplies: 5Last Post: 07-17-2003, 07:51 AM -
OMC mid-range air bleed size???
By jasonyb in forum Technical DiscussionReplies: 10Last Post: 02-19-2003, 07:05 AM
