Results 1 to 2 of 2
12-02-2020, 01:16 AM #1Junior Member
- Jan 2005
- Wellington New Zealand
- 21
280 Mercury cutting out at 4000 RPM
Hi
My 280 is cutting out above 4000 RPM
The engine runs and starts ok
When it cuts out it is a full cut the fuel relays are cut the supply to the coils is also cut
When in the water the engine will fire again when running down The ignition goes through its test cycle ( The overheat buzzer comes on when the ignition cycles just like when you first turn the key on )
We have changed ECM ( With a second hand one that came of a running engine )
We have changed crank angle sensor ( Second hand history unknown ) A new crank angle sensor is arriving overnight
TPS tests ok and was changed out as was the MAP sensor
We have plugged a new remote to eliminate the OEM control box key switch and harness
This engine had a fuel pressure problem at Christmas and the fuel regulator was replaced and it ran fine after that for the 2 weeks of our Christmas break
The next time it was taken out the 4000 rpm cut fault started ( Then NZ locked down and boating wasn't allowed ) Then winter I drained the fuel out over the winter I have replaced the Fuel filter and it now has fresh fuel
This 4000 RPM cut out is consistent and acts the same as turning the Key off
This is driving me nuts
Any ideas
Cheers JohnNothing starts the day better than the sound of an open exhast Merc at full noise and smell of aviation fuel
12-03-2020, 05:15 AM #2Junior Member
- Jan 2005
- 21
Hi
Just a update Make sure when replacing plugs use BPZ as soon as I replaced the plugs with resistor the problem went away
The funny thing is we had done 3 days on the wrong plugs without problems ( In saying that we were only running at low revs )
The correct plugs solved the problem
We had a previous problem when the fuel pressure regulator flooded the engine we went to the local marine shop and were sold the non resistor plugs We replaced the plugs and then figured it was the pressure regulator Replaced the regulator and left the new wrong plugs in it
Its sorted now
Lets go racing
Cheers
I need mercury control handle 4000 gen II
By PotomacBass in forum Misc. Parts and AccessoriesReplies: 0Last Post: 02-16-2018, 04:41 PM -
1987 Mercury 2.4 200 breaks up over 4000
By 280chevzy in forum Technical DiscussionReplies: 2Last Post: 03-16-2015, 07:47 AM -
Mercury Tech: 225 PM cutting out when throtle applied at speed above 4000 RPM
By Mod PM in forum Technical DiscussionReplies: 2Last Post: 07-15-2012, 12:04 AM
