Results 1 to 6 of 6
    Mar 2012
    Lake Hopatcong, NJ
    CLE LH 4-Hole Lower, needs assembly
    Cleaning out all my 2.5L parts. This is a complete 1.87 4-hole LEFT HAND CLE that was disassembled for inspection after purchase and then never reassembled. Good for parts or reassembly as a working unit. I did run it before disassembly and it worked great. A little corrosion here and there on the case but otherwise in great shape. Case also has a lower water pickup fitting that was professionally added, a very nice job. $800 plus shipping for everything. Please PM if you have any questions. This is packed well and ready to ship, but it's large and heavy (36x24x13, 65 lbs). No local pickups.
    Attached Thumbnails Attached Thumbnails IMG_3806.jpg   IMG_3821.jpg   IMG_3819.jpg   IMG_3816.jpg   IMG_3815.jpg
    Mar 2012
    Lake Hopatcong, NJ
    More pics
    Attached Thumbnails Attached Thumbnails IMG_3752.jpg   IMG_3807.jpg   IMG_3808.jpg   IMG_3750.jpg   IMG_3751.jpg
    Jan 2020
    Pinole, Ca
    If you don't mind me asking, what is the big bushing for on the propshaft? When I pulled my CLE apart, mind you its a much newer CLE, it did not have that.
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
    Jul 2013
    Flange for left hand rotation propshaft bearings. Guessing you pulled apart a right hand rotation.
  5. Likes 25two.stroke liked this post
    Mar 2012
    Lake Hopatcong, NJ
    Sold
  7. Likes hackenbrook15 liked this post
    Jul 2020
    Canada
    Thanks Joe! Very easy seller to deal with!
  1. Mercury Tech: What lower unit seal kit? ... Mod VP 2 hole lower on a 2.4L
    By lbhsbz in forum Technical Discussion
    Last Post: 04-02-2018, 02:54 PM
  2. Replies: 9
    Last Post: 09-11-2015, 04:48 PM
  3. CLE 4 hole lower
    By stevo18 in forum Lower Units
    Last Post: 03-22-2015, 09:37 AM
  4. Merc Lower Unit Assembly
    By Jsteve29 in forum Technical Discussion
    Last Post: 05-26-2006, 01:36 PM
  5. 2-hole VRS 4-hole CLE lower units...
    By jrumon in forum Technical Discussion
    Last Post: 04-15-2004, 10:42 PM
