Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 46 to 60 of 77
  1. #46
    Picked up a Brucato ACU and a Brenden Powers slide intake from a guy. But I didn't get any mounting directions. I can see several ways to mount the ACU.
    Use the bracket or not use the bracket?
    I think it is a more cleaner look to mount the ACU strait to the black slide intake with 2 of the rubber studs. The 3rd hole won't line up to anything.
    Attached Thumbnails Attached Thumbnails 20210111_202226.jpg   20210131_191847.jpg   20210131_191928.jpg   20210131_191938.jpg
  2. Likes tnelsmn liked this post
  3. #47
    Sep 2008
    louisville
    Like this ?
    Attached Thumbnails Attached Thumbnails 09A24322-D80E-4A74-AC22-9D44DAE6B2C4.png
  4. Likes LakeFever liked this post
  5. #48
    Quote Originally Posted by pkstv View Post
    Like this ?
    Yes. Please post more pics of the mounts
  6. #49
    Sep 2008
    Dow, IL \ Theodosia Mo.
    Mount in the boat is cleanest in my opinion. Think CDI has extension harness
  7. Likes tnelsmn liked this post
  8. #50
    Sep 2008
    louisville
    Here’s mine directly mounted to the injection body
    Attached Thumbnails Attached Thumbnails 5166C404-9C84-4801-AD9E-96303F01EF64.png   74A3C30D-A910-49D7-9408-7CEB2881B04F.png
  9. Thanks roadkill636 thanked for this post
    Likes roadkill636, tnelsmn liked this post
  10. #51
    Would there be anything wrong with eliciting the big bracket that is between the ACU and the intake? Such as this?
  11. Likes HavasuDreamin' liked this post
  12. #52
    Sep 2008
    louisville
    Quote Originally Posted by roadkill636 View Post
    I’m not sure . You probably need to call Brendan Powers’s at powered performance or David Dreifort to be sure not to damage anything
  13. #53
    Jan 2003
    Indy
    That looks a lot cleaner without the double bracket.
  14. #54
    I worked on it last nite and was able to fit the ACU to the slide intake with very little work. The front two holes on the slide lined up with the Brucato bracket. But the single rear hole didn't have anywhere to go. It may bee fine with just the front two. Bit I drilled and tapped the reed plate for a rear mount also. Using all 3 rubber mounts I really like the way this turned out and cleans up the front. Personally I dont see any reason to use the large bracket at all.
    Attached Thumbnails Attached Thumbnails 20210204_194432.jpg   20210204_195133.jpg   20210204_195916.jpg   20210204_195938.jpg   20210204_200940.jpg
  15. #55
    Mar 2014
    TN
    Very cool post you have here. I'm especially interested in the intake you have installed. What did you previously have installed for an intake?
  16. #56
    Had a stock laser injection system. Full vst and mercury A6 ecu
  17. #57
    Mar 2014
    TN
    What does A6 mean?
  18. #58
    Jan 2003
    Indy
    Quote Originally Posted by Eh2000 View Post
    What does A6 mean?
    That is the fuel curve that was in the ECU.
  19. Thanks roadkill636 thanked for this post
  20. #59
    Jun 2018
    Floating around
    Curious about gain numbers from the slide intake as well
  21. #60
    It will be nearly impossible to tell what advantages the slide had done. Remember this was a stock Promax that has has been bored new pistons intake and ACU all done to it over the winter. So I'm hoping it will push my Viking a lil quicker.
  22. Likes LakeFever liked this post
  1. Ported promax block
    By suprmag225 in forum Misc. Parts and Accessories
    Last Post: 07-22-2020, 08:21 AM
  2. 1996 2.5 mod ported promax block. .030 over big bearing.
    By superboattwin250 in forum Misc. Parts and Accessories
    Last Post: 03-06-2016, 08:34 PM
  3. Brand New ported 225 promax
    By dez nuts in forum Outboard Engines
    Last Post: 08-12-2014, 05:17 PM
  4. new ported 200 promax
    Last Post: 08-12-2014, 01:38 PM
