Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 77
    Sent the block to the machine shop to get bored.
    He called and said it will bore 0.015" no problem.
    Going with Vertex coated pistons. He found a cravk in the bottom of the block where the 2 studs meet the exhaust divider. Says it common and would weld it up better and stronger. Also asked about porting. What boat it going on and what I want the engine to do.
  2. Thanks SS Minnow thanked for this post
    Likes SS Minnow liked this post
  3. #17
    Sep 2002
    Dunlap,TN.
    The exhaust ports look like that from the factory on the FF and PM sleeves due to how they are cut. I raised the exhaust to 1.540 shelf and 1.450 chamfer and smoothed the corners. This is a proven port map. The exhaust divider surface was welded and filled like a 260 in the corners. Oil injection gear was filled. Broke in and set up correctly it should be a strong runner especially with the addition of the slider and ACU. I haven’t had a chance to look at the curves as I am still at the hospital with my wife. Hopefully she will go home today an I can compare the curves and make a determination of which one you need.
    James Perry
  4. Thanks roadkill636, bullet20vee thanked for this post
  5. #18
    May 2013
    Huntiington Beach Ca
    Glad to hear your wife is heading home with good health.
    Don't give up all of Roadkills and Last Minute Racing's secrets.��
  6. Thanks roadkill636 thanked for this post
    Likes roadkill636 liked this post
  7. #19
    Removed the 2 stage reeds and lapped the cages down to 400gt. Good thing too. One cage had a bad casting flaw in it rite on a sealing surface. Took a good bit of lapping with 180gt to get it true and flat again. And installed some single stage custom cut fiber reeds.
    Attached Thumbnails Attached Thumbnails 20201008_194841.jpg   20201008_190812.jpg   20201009_193226.jpg
  8. Thanks SS Minnow thanked for this post
    Likes tnelsmn, SS Minnow liked this post
  9. #20
    May 2013
    Quote Originally Posted by roadkill636 View Post
    Are those stock PM reed blocks or machined 7 pedal tear drop blocks
  10. #21
    They are NOT tear drop
  11. Thanks SS Minnow thanked for this post
  12. #22
    May 2013
    So those are stock PM reed blocks? I've never owned a PM. I have a set of tear drop style that I can opened up if that's what PM's came with. Thanks
  13. #23
    Dec 2001
    Tear drops bend easyer.... flow more..... JMO......The narrow section is where the reed bends.....easyer than straight cut ......It don't flow down below.... the 1/2 mark unless ya blend the surface.......JMO.....And that exhaust port work was sloppy..........
  14. Thanks Baker343 thanked for this post
  15. #24
    Got the block back from James. And he did a wonderful job. Excellent attention to detail. Welded the bottom up and cut like a 260. Bored 0.015" all 6. Filled oil gear. Ported. Milled exhaust and deck flat. And and got the bunny stamp of approval
    Attached Thumbnails Attached Thumbnails 20200924_200303.jpg   20200924_201430.jpg   20201003_162942.jpg   20201003_163002.jpg
  16. #25
    Deck to piston at TDC, gasket thickness, squish clearance, psi ?
  17. #26
    Intake side exhaust side sqiish.
    I never measured squish before so I probly did it wrong
    Attached Thumbnails Attached Thumbnails 20201120_130539.jpg   20201120_130521.jpg
  18. Thanks SS Minnow thanked for this post
    Likes SS Minnow, tnelsmn liked this post
  19. #27
    75 gaskets 35cc heads.
    I'm still in break in mode with 25-1 oil and 43psi fuel and they all settling down at 140-143psi so far
  20. Thanks SS Minnow thanked for this post
  21. #28
    Aug 2020
    Abingdon Virginia
    Road Kill, Who did you say shortened your mid? I have a 20 id like cut to a 15. Thanks
  22. #29
    Quote Originally Posted by Blackmotorsmatter View Post
    Chris Carson shortened my DRIVESHAFT
  23. Thanks SS Minnow thanked for this post
  24. #30
    JAX. FLORIDA
    That porting job looks perfect. He should be a brain surgeon with that kind of skill.
    "Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
    I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington
    “I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
    Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
    Allison GSE 300XS
  25. Likes roadkill636 liked this post
  1. Ported promax block
    By suprmag225 in forum Misc. Parts and Accessories
    Last Post: 07-22-2020, 08:21 AM
  2. 1996 2.5 mod ported promax block. .030 over big bearing.
    By superboattwin250 in forum Misc. Parts and Accessories
    Last Post: 03-06-2016, 08:34 PM
  3. Brand New ported 225 promax
    By dez nuts in forum Outboard Engines
    Last Post: 08-12-2014, 05:17 PM
  4. new ported 200 promax
    Last Post: 08-12-2014, 01:38 PM
