Results 1 to 2 of 2
    Feb 2013
    Australia
    Cool Merc 2.5ltr 2003 with Auto Oil drama.
    Greetings from down under!
    I have owned my Merc 2.5ltr EFI 150hp Limited Edition (Retro) 25" outboard, since brand new in the carton.
    A few months ago whilst underway, the Oil alarm was sounded. I discovered the cap on the reserve oil bottle under the cowl had popped up about 2-3mm (1/8") and was leaking oil. I retightened it by hand, started the motor and within five minutes the alarm sounded again. I removed the cowl to find the cap had popped up again. I retightened it by hand for the second time, then I found the thread of the reserve bottle was actually stripped (threaded).
    I located a used bottle, checking the thread condition of the bottle first, fitted it to my motor... problem solved! Yeah
    After about 6 trouble free outings in my boat and say 6 engine hours later, the alarm sounded again. I immediately stopped the motor checked the oil level of the primary oil bottle located in the boat, the primary bottle was at least half full. However, I noticed two pronounced white stress marks on the front face of the primary oil bottle, plus it was very puffed up.
    Then, I removed the cowl and checked the cap of the replacement reserve oil bottle. The thread of that bottle was stripped, exactly the same as my original reserve bottle.
    Is there a possibility of something causing over pressurization of the Auto Oil System?
    I'm at a total loss of what steps to take next, all suggestions will be appreciated.
    Thank you in advance,
    Guy.
    Apr 2017
    pa
    5 Post(s)
    Most of us remove the oiling system and premix. Probably not a bunch of knowledge about oil systems on this site. Try Bass Boat Central. They deal with many more stock motors on that site.
  3. Likes rgsauger liked this post
  1. Merc 2.5ltr 2003 with Auto Oil drama.
    By Old boy in forum Technical Discussion
    Last Post: 11-29-2020, 06:55 PM
  2. V6 Merc 2.5ltr with bad ignition miss
    Last Post: 01-31-2018, 03:38 PM
  3. 2003 mirage ski racer with 2003 merc 225x
    By jmirage04 in forum Hulls up to 20'
    Last Post: 10-23-2016, 10:12 AM
  4. HELP.Ecu Drama 175XRI maybe needed
    By aaronmt73 in forum Technical Discussion
    Last Post: 11-06-2008, 07:36 AM
  5. Rather strange engine miss issue...? 2.5ltr Merc
    By Bartman39 in forum Technical Discussion
    Last Post: 06-17-2007, 10:38 PM
