Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 46 to 60 of 102
  1. #46
    Jun 2018
    Floating around
    Wow, that’s a ton of work. Never seen anything like it. Hats off for the innovation
  2. Thanks NZ Sidewinder thanked for this post
  3. #47
    Very cool project. Making your own parts is so time consuming.
    Nov 2020
    New Zealand
    Today I finished the wings and started back on the lower Unit.
    The water feed tubes are tacked up.
    The pipes almost meet in the middle and are coupled with sturdy rubber hose.
    Also tapped the feed tube holes.
    Someone at Mercury must have been thinking of us when then dimensioned that water gallery.
    The final finishing of the epoxy on the unit can wait till last now.Click image for larger version.
Name:	wings finished.jpg
ID:	489729Click image for larger version.
Name:	water feeds tacked up.jpg
ID:	489730Click image for larger version.
Name:	feed tube thread.jpg
  5. Likes LakeFever, tnelsmn liked this post
  6. #49
    Nov 2020
    New Zealand
Name:	pinion gauge in bullet.jpg
ID:	491104Click image for larger version.
Name:	pinion gauge.jpg
    Its been slow work but Im trying to just take my time and get it right.
    Ive been making tools as well and putting the box together with old components just for practice and to work out where the traps are.
    Tonight I worked out that a bit of heat into the bullet with a heat gun makes the main forward cone go in really easy.
    No hitting required just a few taps on the tool.
    I cut the inner race of the forward gear off with a grinder or at least ground the race down to paper thin on two opposite sides then used the puller to pull it while heating the thin parts with the heat gun.
    In my early days I cut lots of these bearing races off with the oxy /acetylene torch.
    Not a job for the faint hearted.
    My pinion gauge tool locates on 3 places, the rear carrier ring, the main carrier ring and the forward bearing needle roller and also in the gear shift spigot journal if there is no gear in place.
    The Carrier is bushed down to 32mm for the gauge shaft
    The gauge is an adjustable 3/8 UNF bolt with lock nut.
    The head of the bolt is polished spherical
    Its set at a radius of half the 2.575inch.
    Currently this box with a new drive shaft thrust bearing has 20 thou pinion clearance with a 30 thou shim so I need a 35 thou shim
    Hope there is such a shim.
    Ive got a good offshore midsection for my Promax but am going to put some serious work into designing a way to use the one piece adapter on the steel motor.
    In the mean time Ill run the fisho leg and 2 piece.
    Im thinking a Pan plate with no dump holes in it but just a small barbed hose fitting through the plate into the one piece and a hose that goes out through the case maybe with a flow regulator on it.
    The entire one piece dump cavity with drain holes blocked could then become a poppet cavity with just one poppet drain .(dry Stacked)
    The water pump could be cooled directly from a lower water feed tube, maybe 1/8 jet in through the lower case.
    Looks like Ill have to either pull my power head off again to measure the pan (cowl plate) up so I can create a .dxf file to laser cut a modified one or try and borrow a plate to measure up. (big job)
    Ill measure up the gaskets in that area as well and get them CNC cut here as well.
    Its a bloody long way to get stuff from the States and Im learning real fast that boat shops dont really want to deal in parts for 20yr old Pro Max's.
    Note
    When a pinion gauge like this is used you will find out real easy if your box is bent as the shaft will bind.
  7. #50
    Nov 2020
    New Zealand
    Today I had a win
    I bid on an Optimax Lower unit with a 25inch 13 tooth top spline.
    I bid 400 buck thinking it might contain some usable parts but then again it might be junk.
    I was the only bidder and won the on line auction.
    The unit arrived today and it turned out to be a mint V6 lower full of good condition parts.
    Just a C4 but ill put a 3.0L carrier in it and add a cone etc.
    I have 4 now.
  8. Likes LakeFever liked this post
  9. #51
    Nov 2020
    New Zealand
    This beauty arrived today and next job is to design a workable way of running it with stats and a poppet.
    I do have a plan.Click image for larger version.
    Its mounted on modified fishing bracket with two pin trim.
  10. Likes LakeFever, tnelsmn liked this post
  11. #52
    Nov 2020
    New Zealand
    Today I got a few new bearings to use and also made a seal retainer .
    These 3.0L carriers come with threaded holes in two opposite webs.
    They look like 3/16 fine ?
    They look ridiculously small for pulling with so I reckon they must be there for a seal retainer.Click image for larger version.
Name:	seal retainer.jpg
ID:	491919Click image for larger version.
Name:	new type of bearing.jpg
    Today I also spoke with my gasket maker and he reckons I could use 1.5mm (.060inch) graphite paper reinforced with stainless steel mesh.
    He reckons his CNC cutters will cut it easy so thats really cool.
    He will cut a Cowl pan pattern and some powerhead gaskets from .3mm paper as a trial for me to test then do the real thing.
    The pan plate will be cut from 304 ss.
  12. Likes LakeFever, tnelsmn liked this post
  13. #53
    Nov 2020
    New Zealand
    Ive been testing propshafts for straightness and had some surprises.
    One that wasn't a surprise was an Alpha shaft that I got out of a damaged complete unit that hit a rock.
    Its shaft was bent .010 through the carrier bearing which is more or less the mid point.
    The other 3 were outboard shafts and all were within .0005 at the Carrier bearing journal but the surprise was that the prop spline shafts of two of them were way out of concentric with the fat part at the thrust washer shoulder position
    One was .0045 inch, one was .0012 and the good one was .0005.
    This is strange in that between centers the bearing journals are fine but the prop shafts are not straight.
    Is this typical?
    Also found that the gear select pin that goes inside the propshaft was different in the big bearing case.
    It has a double length pin with a spring inside as well as double indent plugs and double retainer springs on the dog clutch.
    I dropped an indent ball from another shaft on the floor and while looking for it found an old 2 piece exhaust plate gasket hiding under the bench so spent a morning during lockdown drawing it up in CAD for CNC cutting.
    These ones are very complex to draw and that edge shaping is a real headacheClick image for larger version.
Name:	runout tests.jpg
ID:	492080Click image for larger version.
Name:	aceship gasket.jpg
    Update
    I put the worst shaft back on the jig to try and get to the bottom of the issues.
    The prop spline and thread dial up fine (.0015) so its just the prop spline shaft itself thats not concentric.
    The spline and thread are machined true to the fat part.
    This means that this shaft and others like it are out of balance but I doubt that it matters much.
  14. Thanks LakeFever thanked for this post
  15. #54
    Nov 2020
    New Zealand
    I put a coat of 1k primer on it to look for defects and I'll sand it off and it doesn't look too bad.
    Lots of time in this box and another to do yet.
    Can't have too many of them.Click image for larger version.
Name:	primed lower.jpg
  16. Likes tnelsmn, 282, 89LASER, LakeFever liked this post
  17. #55
    Jun 2018
    Floating around
    Impressive piece, your a dedicated man
  18. Thanks NZ Sidewinder thanked for this post
    Likes 89LASER liked this post
  19. #56
    Nov 2020
    New Zealand
    Thanks.
    Next one will have the same terminator type stainless steel skeleton but I'll try and pick up the water from the very lowest part of the underside of the bullet.
    The removable bullet tip will remain as a pickup option though.
    Those bullet tips are dead easy to make .
    I just cast a cylinder of epoxy in a lid from aerosol can with the wall extended a little with aluminium tape.
    This one has a 10mm thread tapped deep into the casting but will try casting the thread next time
    The feed holes are drilled while the epoxy is still in the mold and the profile and locating shoulder are created by spinning the casting on a stud in the tapped center hole.
    I spin it in a battery drill while shaping it with a 36 grit sanding disc on a 5 inch angle grinder.
    Very easy and fun job.
  20. Likes LakeFever, tnelsmn, 89LASER liked this post
  21. #57
    Nov 2020
    New Zealand
    Started another lower unit today.
    It takes about 2 hours to fold up and weld the spine water duct.
    This one will take a fraction of the time that the last one took.
    I found a mint set of non ratcheting gears for it but will investigate whether I can use a ratcheting clutch with those gears.
    The drive shaft I'm going to use has a 13 tooth top spline so that needs to come off and be replaced.Click image for larger version.
ID:	492422Click image for larger version.
    The weather is warming up now so I'll be able to get back to the hull.
    We are currently in a lock down which is a boat builders paradise.
  22. Likes LakeFever, tnelsmn liked this post
  23. #58
    Nov 2020
    New Zealand
    Today's work.
    This low water pickup is slightly different than the last one.
    Its lower and larger, hopefully not too large and hopefully the water flow wont eddie in a turn.
Name:	spine on lower.jpg
ID:	492470Click image for larger version.
Name:	spineand mock nose.jpg
ID:	492471Click image for larger version.
Name:	trial contour.jpg
    The bullet nose shown is just a wooden dummy and not the correct profile.
    Importantly that little stainless inlet duct behind the bullet point will get a small stainless flange tomorrow so that
    The polyester filler can go behind the flange so that there isnt a join in materials that high pressure water can penetrate and possibly de laminate.
    That point screws on and off so I can revert to a conventional bullet point water intake if this one doesn't work.
    Overall this lower will be 3/8 inch longer than the one in post #53
    In case anyone is wondering how I get that threaded rod straight and true to the center line of the case, I have a mandrel that slides down the inside of the case into the gear selector journal.
    A 8.5mm long drill fits through the mandrel and drills from inside to outside.
    Then the tap goes from the inside out ways as well.
    The thread is sealed with Locktite 577 and a nut.
    Later on in the process the unit is held at an angle in a vice so that poured epoxy creates a 45 deg ramp that defects water from the horizontal to the vertical and this epoxy buries the lock nut on the thread.
    IMO Mercs that work hard should also look hard and for this reason I dont really like the Alien Cowls so today I brought a complete cowl setup to restore.
    Ill set it up to fit my Pro Max and overall with the offshore leg and make believe sporty lower it will at least look like a race MercClick image for larger version.
  24. Likes LakeFever liked this post
  25. #59
    Nov 2020
    New Zealand
    The skeleton is almost done now.
    Just the 1/2 inch socket to be fitted for outfeed to the pump.
    This nose is a dummy wooden one.
    I sandblast the stainless then use polyester Auto filler as a butter layer then epoxy over the poly.
    This works well on the Aluminium also.
    We get out of lockdown tomorrow so Ill be able to pick up a few bits and pieces to finish it.
    Ive found that polyester Bog has much better adhesion to prepped Aluminium than Epoxy does.Click image for larger version.
ID:	492553Click image for larger version.
ID:	492554Click image for larger version.
Name:	single pickup.jpg
    The poly bog I use has the glass reinforcing in it.
    Ill probably add a stainless vertical jail bar to that intake throat.
  26. Likes 89LASER, JAFFA, Jono K, tnelsmn liked this post
  27. #60
    Nov 2020
    New Zealand
    Here is that skeleton with some flesh on it.
    This one is slightly different to the original in the background.
    It has a more aggressive and lower water pickup and is slightly finer in shape.
    It will get one top layer of Epoxy cloth over the walls of the Gearbox and carrier case and also an epoxy cloth layer from the leading edge of the crescent back to the trailing edge.
    These are cheap and easy units in the context of something to do over lock down but in the real world they dont really stack up price wise.
Name:	2 units.jpg
  1. 21 Superboat Millenium, complete custom restoration
    By WILDMAN in forum Photos and Videos
    Last Post: 01-25-2023, 03:32 AM
  2. Allison XST18 Restoration Complete
    By freeebird in forum General Boating Discussion
    Last Post: 07-14-2021, 08:03 PM
  3. 21 superboat millenium, complete custom restoration
    By WILDMAN in forum General Boating Discussion
    Last Post: 06-03-2019, 09:35 AM
  4. Phantom 25 - 30 years ol getting complete restoration
    By Toffen in forum General Boating Discussion
    Last Post: 05-23-2015, 11:56 AM
  5. My 1971 Sidewinder Restoration
    By Contractor in forum General Boating Discussion
    Last Post: 08-25-2011, 07:09 PM
