Results 1 to 3 of 3
11-26-2020, 07:31 AM #1
5000 RPM
- Jan 2005
- Annapolis, MD
- 382
- 12
Quick question about prop pitch and gear ratio
One of my boats is a 20 Ft. Sea Ox with a console and T-top. I have a 2.5 liter Merc 200 on it that runs very strong. I have a quick question about prop pitch and gear ratio.
In terms of efficiency - both in terms of gas mileage and speed, would I be better off running a 21 pitch with a 1.875 gear ratio or say a 23 pitch on a 2.0 gear ratio lower?
What I'm asking is - for this boat in particular and in general - would a faster spinning lower pitch prop be more or less efficient than a slower spinning higher pitch prop? Would one get better mileage and the other get better cruising and top speed?
Appreciate your experiences and advice.
Steve2ManyBoats.
11-26-2020, 10:58 AM #2
You probably won't notice any real change in speed or mileage, might accelerate slightly better.
11-27-2020, 07:29 AM #3
In lower prop speed applications, it's a wash. When you're turning 8 or 9k + rpm is when it starts to matter based on hydrodynamics. In your application, experiment with props and run the one that works best for ya
Optimum prop pitch vs. gear ratio
By MetricMuscle in forum Props, Setup, and RiggingReplies: 4Last Post: 09-22-2015, 07:15 AM -
Gear ratio VS prop pitch
By Techno in forum Technical DiscussionReplies: 18Last Post: 01-03-2014, 12:51 PM -
prop pitch vs gear ratio help
By Fluid in forum Props, Setup, and RiggingReplies: 8Last Post: 06-26-2006, 08:50 AM -
different ratio/prop pitch
By indiana jack in forum Technical DiscussionReplies: 1Last Post: 06-12-2006, 01:10 PM -
Different gear ratio now what pitch??
By 79Tron in forum Technical DiscussionReplies: 5Last Post: 04-12-2005, 07:51 AM
