Results 1 to 5 of 5
11-25-2020, 07:58 AM #1
Sandblast finish on trailing edge and cup ?
Hi Guy's
Been looking at a certain stainless steel prop for a while and I like the idea if it is something that would work.
this is NOT my prop in the photo just for a example.
The prop in the photo and my question is about the blasted finish on the trailing edge of the blade, looks to be a
bout 3/4 inch wide along the trailing edge including the cupped areawhat I am wondering is,
would this be of any advantage to have this on the blades. I.E to help keep grip or aid in any way at all ?
or is this purely just a cosmetic thing purely for looks ?
Does something like this sort of aid in adding like a bit of pitch being as the water flow would be held on a bit more ?
I could be completely on the wrong track looking at this,
but thought it worth a mention, ive seen this on few props over the last couple of years.
photo of propeller with blasted trailing edge for example (not my prop)
11-25-2020, 10:16 AM #2Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Merc says that the rough finish helps to collapse any air bubbles and help with slip numbers. All the choppers had them "new" from my memory. My labbed lightning ET has it from merc. prop shop.
11-25-2020, 11:47 AM #3
your labbed lightning et has the sandblasted edge like in the pic I posted yeah ? in that case sounds good to me
any chance of a pic of your prop with this finish ?
11-25-2020, 12:10 PM #4Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
It's not sandblast on the mercs. It's a small D/A disc sander finish. 80 grit I would guess. About 3/4'' or so.Same idea tho. Ruff blast would work same. My lightning is at a friends house at the moment. I don't have pics...Only chopper I have now is polished. Sold 2 big blade choppers that were virgins, they had it.
11-25-2020, 12:14 PM #5
thanks for the info.
i think i will find some nice thick tape and run a nice 1/2 band , will use glass beads ( as thats all i have for blasting at the moment).
i have a bit of scrap stainless i will polish and have a practise on first...
its just something i have liked the look of to give a sort of custom finish and was hoping it might help a touch.
As long as it dont pull the rpm down too much i will be very happy with it
thanks again for infoLast edited by phillnjack; 11-25-2020 at 12:23 PM.
32 Lightening ET Lab finish, Balanced & Blueprinted, worked by Leading Edge Propeller
By Air&Sea in forum PropellersReplies: 2Last Post: 02-02-2018, 08:06 AM -
Stainless prop leading edge finish?
By nowgrn4 in forum Props, Setup, and RiggingReplies: 6Last Post: 08-23-2016, 07:09 AM -
leaving trailing edge a little jagged as it comes up from pad
By 200VEGAS in forum General Boating DiscussionReplies: 7Last Post: 11-07-2011, 05:57 AM -
Anyone trim trailing edge of thru hub prop for speed
By stoker2001 in forum Technical DiscussionReplies: 8Last Post: 02-24-2006, 12:48 PM -
Sandblast or Sand????????
By 302Sport in forum Appearance ModsReplies: 3Last Post: 09-23-2005, 10:32 PM
