Results 16 to 24 of 24
11-26-2020, 07:32 AM #16Team Member
- Lake Coochiching, Ontario
- 7,766
- 276
- 487
- 1590
- 6 Post(s)
You can run a sport master on your boat and nothing bad will happen. It might not be the fastest option but so what. Your boat will be a lot faster than with the 115
11-26-2020, 04:27 PM #175000 RPM
- Mar 2020
- netherlands
- 163
- 14
Thanks David, thats exactly what i needed to hear
11-27-2020, 11:19 AM #185000 RPM
- Mar 2020
- netherlands
- 163
- 14
This morning i went to visit the owner of the motor. What do you all think? Looks very clean under the cowling, but a couple of things are missing:
Temperature switch on the left cylinder bank (is it supposed to be there?)
Throttle linkage between carbs
Also the brown small hoses are very hard, not bendable
11-27-2020, 11:38 AM #19
Port side sender is for temp gauge, stbd is for overheat alarm. Bleed lines are easy to replace, if they are bad chances are the one between upper and lower crank bearings also needs replacing.
David - WI liked this post
11-27-2020, 01:45 PM #205000 RPM
- Mar 2020
- netherlands
- 163
- 14
Thanks for your help Dave!
I noticed this when i spun the prop by hand, makes a little biy more noise then im used, or maybe there is no oil in the LU? It has been sittiny for 2 years
https://youtu.be/DultX6F72nM
11-27-2020, 01:51 PM #21
11-28-2020, 08:45 AM #22
may be jus cause i'm old and don't remember for sure but don't think tha "only" xr2 i had had a drilled oiler boss???..
11-29-2020, 12:39 PM #235000 RPM
- Mar 2020
- netherlands
- 163
- 14
11-29-2020, 01:09 PM #24Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Might be the shifter is just off and the dog is touching the gear......You should buy it.....cause there are not many in your area. JMO
20 inch 2L merc with CLE on 25 inch transom
By killerpirate in forum Technical DiscussionReplies: 0Last Post: 11-24-2020, 07:50 PM -
1998 merc 3.0 liter 250efi cowl and pans, 25 inch mid, 25 inch lower sei
By superboattwin250 in forum Misc. Parts and AccessoriesReplies: 1Last Post: 01-20-2015, 07:54 PM
