Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
    Lake Coochiching, Ontario
    You can run a sport master on your boat and nothing bad will happen. It might not be the fastest option but so what. Your boat will be a lot faster than with the 115
  2. #17
    Mar 2020
    netherlands
    Thanks David, thats exactly what i needed to hear
  3. #18
    Mar 2020
    netherlands
    This morning i went to visit the owner of the motor. What do you all think? Looks very clean under the cowling, but a couple of things are missing:
    Temperature switch on the left cylinder bank (is it supposed to be there?)
    Throttle linkage between carbs
    Also the brown small hoses are very hard, not bendable
ID:	477860Click image for larger version.
ID:	477862Click image for larger version.
ID:	477863Click image for larger version.
  4. #19
    Port side sender is for temp gauge, stbd is for overheat alarm. Bleed lines are easy to replace, if they are bad chances are the one between upper and lower crank bearings also needs replacing.
  5. Likes David - WI liked this post
  6. #20
    Mar 2020
    netherlands
    Thanks for your help Dave!
    I noticed this when i spun the prop by hand, makes a little biy more noise then im used, or maybe there is no oil in the LU? It has been sittiny for 2 years
    https://youtu.be/DultX6F72nM
  7. #21
    Quote Originally Posted by killerpirate View Post
    Does not sound great, would not run it like that.
  8. #22
    TX......somewhere?
    may be jus cause i'm old and don't remember for sure but don't think tha "only" xr2 i had had a drilled oiler boss???..
  9. #23
    Mar 2020
    netherlands
    Quote Originally Posted by Dave Strong View Post
    Owner told me its probably because there is no oil in the LU (he didnt run it since he bought it)
  10. #24
    Dec 2001
    Might be the shifter is just off and the dog is touching the gear......You should buy it.....cause there are not many in your area. JMO
  1. 20 inch 2L merc with CLE on 25 inch transom
    By killerpirate in forum Technical Discussion
    Last Post: 11-24-2020, 07:50 PM
  2. 1998 merc 3.0 liter 250efi cowl and pans, 25 inch mid, 25 inch lower sei
    By superboattwin250 in forum Misc. Parts and Accessories
    Last Post: 01-20-2015, 07:54 PM
