Results 1 to 10 of 10
    Belgium
    Single trim ram / cylinder differences
    Hi, I have two midsections. One has a trim cylinder of a 260. The other has a cylinder of a 280. The 280 cylinder is a bit thicker and more beefier.
    I discovered that the mid with the 260 has more negative trim. The cylinder of the 260 can retract more.
    Is anyone familiar with this? Is it normal or is the 280 cylinder not assembled right? (I have no idea whether it has been taken apart yet in the past).
    I realy need the extra negative trim the 260 cyl has.
    Thanks for your input
    Regards
    http://www.geocities.com/fletcher_arrowbeau
    Fletcher 17F6
    Hydrostream HST 20F
    Mar 2010
    houston, tx
    Wouldn’t just putting a 2.5 or 5 degree wedge in be easier than swapping rams around??
  3. Thanks bigboy thanked for this post
    The piston travel is the same for both early and late model cylinders . That's not what stops negative travel . The notch cut into the lower guide arms bottoms out against the landing pads on the exterior of the cylinder.
    If you want more tuck under , you can machine/ sand the pads .
    And then machine the rams internal parts to match.
    Don't get carried away .. cuz if the weld holding the top loop touch's the closure cap ... it will be a leaker for sure .
  5. Thanks bigboy thanked for this post
    Belgium
    Hi Chaz, i had to reread your post to get it but it's clear now.
    The fact is that the part that has the vertical steering pin going through is not touching the ram. I can put my finger in between.
    It seems like the piston cannot fully retract although you can feel it is bottomed out.
    You say the piston travel is the same for both styles but is the starting point, fully retracted mode, the same too?
    If this is the case something must be wrong with cylinder.
    Thanks!
    Fletcher 17F6
    Hydrostream HST 20F
    This should clear it up ....
    These external pads are the retracting stops ---->
    When they make contact here --->
    That's it . End of the road . If the hydraulic parts inside were used as the stops . It wouldn't take long to ruin the cylinder.
    Yes you are correct ... fully compressed, there is aprox. 13 to 15 mm between the body and the base of the loop , that is normal (this one is not .. rusted out) -->
    More better ...
  8. Thanks bigboy thanked for this post
    Likes phillnjack liked this post
    Belgium
    Thanks. Very clear. I will dissamble the cylinder.
    Fletcher 17F6
    Hydrostream HST 20F
    Belgium
    I opened up the ram. A spring seat is gone. Found it broken in the bottom of the cylinder. Mercury does not list these seperately?
    I guess the part with the springs in it spun loose and is the cause the trim ram did not fully retract.
    Fletcher 17F6
    Hydrostream HST 20F
  11. Likes David - WI liked this post
  12. #8
    Your center bolt has loosened up . When seated , the spring guide's three prongs fit inside a little step machined into the bypass block.
    I have one here now that someone tightened the assembly without aligning the three tabs and crushed the guides .
    You are correct , they are not sold separately ...
  13. Thanks bigboy thanked for this post
  14. #9
    Belgium
    Yes, one guide has a folded / crushed lip...
    Are they realy necessary?
    Fletcher 17F6
    Hydrostream HST 20F
  15. #10
    Quote Originally Posted by bigboy View Post
    I have never built one without the guides. I guess it you tighten the bolt and can't pry one out with a screwdriver ..... you might be OK ..
  1. Mercury single ram trim cylinder and brackets
    By Pepperson4 in forum Misc. Parts and Accessories
    Last Post: 07-30-2020, 10:00 PM
  2. Dual cylinder hydraulic vs single cylinder on a single engine application
    By 1BadAction in forum Props, Setup, and Rigging
    Last Post: 07-11-2015, 03:42 PM
