Results 1 to 5 of 5
Thread: 1984 Mariner 75 Compression
11-23-2020, 10:34 AM #15000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
There is a 1984 Mariner 75hp I am getting ready to sell, that I think it is in great shape and it runs good. I went to do a compression check on it and the numbers all came up consistently between 175-185lbs. I considered this excellent, but now I'm wondering if this is too high. I did forget to open up the carbs when I tested, but I doubt that would make it go higher as opposed to lower. I'll try the test again, but does this sound normal?
The motor is 2/3's of a Tower of Power, it just has the 4 cylinders inline.
11-23-2020, 10:43 AM #2
try another compression gauge..
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
Capt.Insane-o liked this post
11-23-2020, 10:46 AM #3Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Did you fog it up real good, if so run it clean and try again.
Maybe at some point someone slipped high domes in it too?Last edited by FMP; 11-23-2020 at 10:55 AM.
11-23-2020, 07:29 PM #45000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
So I did try another compression gauge. That was a good idea, but the results was similar, so that is not the problem.
... and to answer the question about fogging, yes it had been fogged a while back for storage, and I sprayed a bit more just before testing because I worry about spinning a dry engine for fear of causing damage. This last time though after I spun it several times and cleared some of that oil out I started to get readings closer to 150. So I believe if I actually ran the engine first and then did a test I suspect it would show something more normal as mentioned.
Thanks for the tips guys.
11-23-2020, 08:10 PM #5Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
So you still have room for the high domes
Glastron1987 liked this post
1984 Mariner 75hp Tune
By Glastron1987 in forum Technical DiscussionReplies: 0Last Post: 07-04-2017, 09:00 PM -
OMC Tech: 1984 omc 75 hp compression
By JoshKeller in forum Technical DiscussionReplies: 25Last Post: 02-19-2016, 05:09 PM -
OMC Tech: 1984 johnson 75 hp low compression
By JoshKeller in forum Technical DiscussionReplies: 2Last Post: 10-03-2014, 07:18 PM -
1984 2.4 compression check
By jimmyz32 in forum Technical DiscussionReplies: 7Last Post: 12-09-2005, 07:31 AM
