Results 1 to 7 of 7
    Eastern PA
    Freeze Plug Number says:
    Neighbor has a Johnson outboard with jet lower. Number on freeze plug is G2642477.
    Can anyone tell me the year model based on this number? Thanks.
    Eastern PA
    Can anyone help me with this identification task?
    Jan 2015
    Quote Originally Posted by 97mirage View Post
    Identification numbers will be somewhere on the mid, usually on a little plate that is riveted to the motor. If you cannot find that, you are best off to snap a bunch of pictures of the motor with and without the cowl.
    I tried running the numbers you posted and it came back to nothing. Not a motor, not a freeze plug, not a nothing.
    If you want to identify it, get some picture posted here, especially the serial number.
    Sep 2017
    Ashland city tn
    I couldn't get anything to come up with that # either
    I also tried with 0 in front like a mrec but didn't help. I thought that the rudes had 2 letters at end of the serial also
    Eastern PA
    Thanks for checking, guys.
    Let me see what else I can find...
    Ft. Lauderdale, Fl
    That freeze plug only having a serial number means the power head was replaced with a factory replacement at some point. With an original power head, the freeze plug will have the model number on it. If there is no plate or sticker either on the clamp bracket or swivel housing, then it's going to be fun figuring out what it is.... will need pictures of the cylinder heads (numbers) carb numbers, power pack numbers.... and dates you can find and over-all pics of the power head.
    Sep 2011
    maryland
    what he said........
  1. Mercury Tech: Freeze plug W?
    By CKMATE225 in forum Technical Discussion
    Last Post: 11-25-2015, 12:50 PM
  2. OMC Tech: Freeze Plug Number
    By Deznuts3570 in forum Technical Discussion
    Last Post: 03-05-2013, 04:42 AM
  3. Replies: 1
    Last Post: 07-05-2010, 11:04 PM
  4. freeze plug keeps blowing out???
    By biggercb in forum Technical Discussion
    Last Post: 03-21-2004, 07:03 PM
  5. number for spark plug ,2.4
    By hydrostream1 in forum Technical Discussion
    Last Post: 08-21-2003, 07:09 PM
