Results 16 to 20 of 20
Thread: Swivel Bracket S/N Help Needed
11-21-2020, 01:26 PM #16
11-21-2020, 01:58 PM #17
Theres a few problems I see with pulling a decal off a clamp.
1. The model numbers don't match unless you find one from the same motor - might be a problem for insurance purposes?
2. The stickers from the newer motors actually destry themselves by design when removed. There is a "warranty void" message left after.
I would probably have a decal made, or try contacting Merc and see if they will send you one. On some things the manufacture will supply a replacement VIN / Capacity decal, not sure how it works with Merc though.
I'm sure these guys could make it, I've purchased from both before with great results.
https://discontinueddecals.com/
https://www.outboarddecals.com/
Blake
www.InjectorService.com
Call/Text - 204-326-0390
11-21-2020, 02:16 PM #18
jus curious?.. why do you NEED a title for motor?.. tex requires one also but not needed ta register boat... titles for both are separate.. ohio different?.. down here 'bout only time tha guys with this sickness titles a motor is for financin', insurance and/or a buyer wants one (resale ta "normal" folks)..... don't know or heard of anyone bein' checked by water cops or any law enforcement for motor title down this way...
11-21-2020, 03:24 PM #19
I thought that the void would show thru, but I said what the hell, try it. It worked w/o the "Void" issue. Yes, mine was from the same model motor package so good! I just wanted to keep the motor title matching the motor. Funny why Merc. has the SN on the bracket instead of the block?? Oklahoma requires both motors and hull to be titled and tagged including twin motor boats = 3 titles, registrations and tags!
11-21-2020, 04:00 PM #20
