Results 1 to 12 of 12
Thread: Overheating Again
11-21-2020, 12:32 AM #1Junior Member
- Nov 2019
- Melbourne
Overheating Again
Hi all, long time reader, first time poster. I'm at a loss, searched many posts, scoured the threads and cant find the solution. Had an '88 200 Carb for 20 years without an issue. This year new water pump housing , impeller etc maiden seasonal voyage today and I get an overheat alarm. For the time in the water, the temp came up pretty quick (quicker than ever) then as soon as I got underway I saw a steady increase in water temp @ 3000 rpm until the alarm reminded me that it was there. First time ever. Here's where I get confused; the telltale is pumping good water but it's hot probably in line with what the temp gauge is telling me. Temps remain high at idle in neutral but holding it at 3500 in neutral brings the temps back to normal with good flow. In gear and we revert to the overheat scenario. Dont know whether anyone else here has experienced this scenario but I'm baffled. WHY do I have an overheat problem in gear with good water flow and experience normal temps in neutral at the same RPM. Id be grateful for any advice.
11-21-2020, 02:22 AM #2Screaming And Flying!
- Dec 2001
- 9,503
- 270
- 191
- 1975
It could be a stuck poppet valve.....Just something to check.
11-21-2020, 09:17 AM #3
I agree with Dave
When the last time the poppet kit has been changed?
When u changed impeller etc , how did it look? Pieces missin?
11-21-2020, 09:19 AM #4
11-21-2020, 11:34 AM #5
What is the water pressure?
11-21-2020, 05:00 PM #6Junior Member
- Nov 2019
- Melbourne
OK, I will check it out
11-21-2020, 05:06 PM #7Junior Member
- Nov 2019
- Melbourne
Poppet has never been changed, we do about 100hrs a season social waterskiing. The impeller gets changed every year, it was starting to get soft but was intact.
11-21-2020, 05:13 PM #8Junior Member
- Nov 2019
- Melbourne
Thanks for all the replies, I'll check out the poppet, never had a need for a water pressure gauge, that's until now. For the first time ever I used an aftermarket kit for the pump and housing and this is the first year I've ever had a problem. Is it just a coincidence or have others had issues with non genuine
11-21-2020, 06:02 PM #9
11-22-2020, 02:49 AM #10Junior Member
- Nov 2019
- Melbourne
OK. Found the problem. For some stupid reason the grommet/seal in the pump outlet had collapsed and almost completely blocked the outlet after 6 attempts with dropping the box we diagnosed the problem, today I learned about the thermostats and poppets but now were good to go. Thanks for everyone's advice everything now seems to be in order. FWIW can now drop the box, replace the impeller and reassemble within half an hr, probably could do it blind. But all good thanks again to everyone.
SS Minnow thanked for this post
11-22-2020, 03:44 AM #11Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
Thanks for coming back to tell us what the problem was. Nice when it is something simple, too.
11-22-2020, 05:32 AM #12Screaming And Flying!
- Dec 2001
- 9,503
- 270
- 191
- 1975
A new Merc man is born..... The cranks chimmed in Merc heaven.
Overheating
By michaelogden in forum Technical DiscussionReplies: 17Last Post: 12-09-2018, 12:50 AM -
Pro max overheating
By Luke Tucker in forum Technical DiscussionReplies: 4Last Post: 09-04-2015, 10:58 AM -
Mercury Tech: 250 EFI Overheating
By vdm in forum Technical DiscussionReplies: 11Last Post: 08-27-2008, 08:18 AM -
Overheating...Help!!!!!
By samann in forum Technical DiscussionReplies: 1Last Post: 07-28-2004, 10:29 PM -
overheating
By YoungStream in forum Technical DiscussionReplies: 4Last Post: 06-23-2004, 04:27 PM
