Results 1 to 6 of 6
    0.039 intake 0.046 exhaust SQUISH
    Just checked my squish.
    0.039 intake side
    0.046 exhaust side. Using 2 pieces of solder.
    225 Promax.
    What ya think?
    Attached Thumbnails Attached Thumbnails 20201120_130539.jpg   20201120_130521.jpg
    I think that piston rock is not a accurate measurement of piston to head clearance. You could call it .0425
    Or you could use one piece of solder directly (parallel) above the "gudgeon" pin to get a true reading ...
  3. Thanks roadkill636 thanked for this post
    Likes roadkill636 liked this post
    Dec 2001
    My thoughts....... How did you get in my head..... and not Die from the Fumes.........
    They say that the "tricks in the wrist" ... but I used my own mask ..
    Are you saying to stick the solder in at 12;00 or 6;00?
    To calculate the Squish accurately and correctly you need to use a Deck Height Gauge perpendicular to the wrist pin. Add the two together divide by 2 + the gasket thickness or on oring heads the Counter bore pocket depth. If Not I always preferred Plasti gauge over Lead wire Youll see a variation of up to .008 ths on most engines.
Name:	Deck Height Tool.jpg
  8. Thanks roadkill636 thanked for this post
  1. Replies: 3
    Last Post: 05-01-2018, 09:23 PM
  2. Intake plus equals exhaust plus right?
    By Quinten in forum Technical Discussion
    Last Post: 03-30-2013, 12:41 PM
  3. Any benefit to cleaning up intake/exhaust ports?
    By Mach2 in forum Technical Discussion
    Last Post: 05-18-2004, 12:10 PM
  4. Better squish?
    By Ryan140 in forum Technical Discussion
    Last Post: 03-31-2003, 06:53 AM
