Results 1 to 6 of 6
11-20-2020, 02:29 PM #1
0.039 intake 0.046 exhaust SQUISH
Just checked my squish.
0.039 intake side
0.046 exhaust side. Using 2 pieces of solder.
225 Promax.
What ya think?
11-21-2020, 12:35 AM #2
I think that piston rock is not a accurate measurement of piston to head clearance. You could call it .0425
Or you could use one piece of solder directly (parallel) above the "gudgeon" pin to get a true reading ...
roadkill636 thanked for this postroadkill636 liked this post
11-21-2020, 02:18 AM #3Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
My thoughts....... How did you get in my head..... and not Die from the Fumes.........
11-21-2020, 09:00 AM #4
They say that the "tricks in the wrist" ... but I used my own mask ..
11-21-2020, 09:33 AM #5
Are you saying to stick the solder in at 12;00 or 6;00?
11-22-2020, 09:39 AM #6
To calculate the Squish accurately and correctly you need to use a Deck Height Gauge perpendicular to the wrist pin. Add the two together divide by 2 + the gasket thickness or on oring heads the Counter bore pocket depth. If Not I always preferred Plasti gauge over Lead wire Youll see a variation of up to .008 ths on most engines.
Question about intake /exhaust air flow capacity versus power output of engine
By H2Okie in forum Technical DiscussionReplies: 3Last Post: 05-01-2018, 09:23 PM -
Intake plus equals exhaust plus right?
By Quinten in forum Technical DiscussionReplies: 11Last Post: 03-30-2013, 12:41 PM -
Any benefit to cleaning up intake/exhaust ports?
By Mach2 in forum Technical DiscussionReplies: 4Last Post: 05-18-2004, 12:10 PM -
Better squish?
By Ryan140 in forum Technical DiscussionReplies: 28Last Post: 03-31-2003, 06:53 AM
