Results 1 to 13 of 13
    Aug 2009
    mpls,mn
    Factory alien cowl repair help
    It's plastic is it made of abs? either way has a lot of cracks in the rear and a big patch of material what ever they used to try and repair it.What is the best glue/adhesive to use and to fill large areas and be able to sand it smooth and get ready for paint.
    Jun 2009
    Bristol, Connecticut
    Flexseal LOL
  3. Likes rgsauger liked this post
    3M Structural Adhesive was the recommended repair product for RIM (reaction-injection molded?) plastic snowmobile hoods; which is what I thought the alien cowls were made of?
    Two part general purpose gray structural adhesive that may be used for bonding metal, glass and plastic. This product can be used for trim, fiberglass, and flexible body parts repair. It is easy to mix, sets up quickly, spreads smoothly, and cures to an extremely strong bond.
    https://www.jbtools.com/3m-08101-str...BoCv0MQAvD_BwE
  5. Thanks CI STV thanked for this post
    Likes racervboat liked this post
    Sep 2011
    maryland
    You can also rough up the inside with course grit and apply epoxy with some fiberglass cloth(very thin 4 oz) to provide some structural support if necessary.
  7. Likes racervboat liked this post
    Oct 2019
    Clearwater, Fl.
    Got any pics?
    Mar 2004
    Brooklyn Park, MN
    This is the top section where it looks #1 melted the cowl some and I was told it was fixed with some 3M 8115, panel bond. But the bottom is busted up as well and that will be a fun spot. Also the seam seems to be letting go in the front and back where the two cowl pieces were bonded together originally.
Name:	top back.jpeg
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Pekin, IL
    I trashed a friends cowl years ago and replaced it with an Eagle1 (don't do it) then had the damaged cowl repaired by another friend that is a body man for a Chevy dealer. Don't know what materials he used but the cowl looked new when he was done. Maybe contact a body shop for advice?
    Rock
    Team Junk
    Mar 2004
    Brooklyn Park, MN
    Quote Originally Posted by rock View Post
    Rock
    thanks again for the help Rock! I think Racervboat found the products that GM uses.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Mar 2015
    DFW
    what he said! prep is key to get a good bond on the plastic but it's not hard at all and can be made to look 100% factory finish.
    Quote Originally Posted by keefallan View Post
    Mar 2004
    Brooklyn Park, MN
    Quote Originally Posted by Noah Burns View Post
    I have read some have used very light glass and G/Flex epoxy from West System with success.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  14. #11
    Mar 2015
    DFW
    I have used the west systems stuff as well as regular old poly resin that part isn't all that important really. ( as far as material goes)
  15. Thanks rjdubiel thanked for this post
  16. #12
    Mar 2004
    Brooklyn Park, MN
    Also, that plastic welder thing from Home Depot or Harbor Freight looks like it would work. Just need some extra plastic off the inner shield of the cowl and melt it all back together!
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Jun 2018
    Floating around
    This seems promising
  18. Likes keefallan, rjdubiel liked this post
  1. Alien cowl repair?
    By Mr. Demeanor in forum Technical Discussion
    Last Post: 04-05-2018, 10:18 AM
  2. WTB factory 3L Alien Cowl
    By Hoovershark in forum Parts Wanted
    Last Post: 05-16-2017, 10:06 PM
  3. alien lower cowl repair
    By bluecheckmate in forum Technical Discussion
    Last Post: 03-27-2009, 10:32 AM
  4. Factory alien cowl repair
    By Scott Tharpe in forum Fiberglass and Composites Discussion
    Last Post: 10-05-2007, 05:30 PM
  5. Merc lt wt factory Cowl Repair????
    By Fish in forum Technical Discussion
    Last Post: 07-27-2005, 10:17 AM
