Results 1 to 15 of 18
11-17-2020, 06:32 PM #1Member
- Jul 2003
- Naples, Florida
- 78
What happens when a two stroke is run without oil?
Does the bottom end fail first or the pistons/rings/cylinders?
11-17-2020, 06:53 PM #25000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
All the above
rgsauger liked this post
11-17-2020, 07:09 PM #3
Yeah...it just sucks all the way around. So be honest...how long did you run it without oil???
11-17-2020, 07:59 PM #4
You can always tell when taking one apart cuz everything's dry as a bone.
RockTeam Junk
tux974 liked this post
11-17-2020, 08:13 PM #5
Piston to walls first.
11-17-2020, 08:50 PM #6Member
- Jul 2003
- Naples, Florida
- 78
My story is I took a work assignment out of country and told a trusted old friend to use my boat whenever. It's a 98 2.5 200 carb fishing motor. It looks like the pressure line to the oil tank cracked. The key harness didn't have a warning horn in place and he heard what he described as a rod knock and shut it down. He gave me two grand which I thought was a nice gesture (that's what I paid for the motor a few years back). I'm a good auto mechanic but I think another used motor might be the smartest move. My other thought is to put premix in a small tank, fire it up and see what it sounds like. Then follow that with a compression test. What would you experts do?
11-17-2020, 10:41 PM #7Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Take it down and see what's what or take a chance and bring a paddle.
11-18-2020, 07:29 AM #8
Pull heads. Capt. is correct, piston to wall first. If you see no transfer you may be ok.
RockTeam Junk
activator22 liked this post
11-18-2020, 11:26 AM #9
I have a drop on 2.5 200 for sale if you need
11-18-2020, 03:13 PM #10
11-18-2020, 04:26 PM #11
That is a good block. Tear it down and fix it properly..that one will have plastic caged rod bearings which will fail quickly too under a no oil situation.
David - WI liked this post
11-18-2020, 04:47 PM #12
Bought a Glastron Ski Machine forever ago without motor. Installed a good running 2.0 150. Went about 1/2 mile and toasted motor. Disassembled and everything was dry as a bone. I had drained and filled fuel tank with premix but did not notice previous owner had an auxiliary fuel tank and his motor was oil injected therefore zero lube. I was amazed at how quick they can fry.
RockTeam Junk
11-19-2020, 11:47 PM #13
Funny story, back in 1979 I was racing desert on a 175 Yamaha. I ran out of gas about 10 miles from the finish. I got about 1/2 a gallon of straight gas and rode it in easy I might add to the finish. I used Castrol Oil as premix. When I got home I tore it down and everything looked great! I imagine that an outboard would not make it very far because of the loads that are put on the engine from the water drag.
11-20-2020, 12:51 AM #14
11-20-2020, 12:54 AM #15
ok I see Castrol oil in it but 10mi on a v-6 yam on 1/2 gal?
2 stroke to 4 stroke re-power on smaller hull
By miagonz85 in forum Technical DiscussionReplies: 2Last Post: 07-25-2018, 09:02 AM -
By miagonz85 in forum Props, Setup, and RiggingReplies: 1Last Post: 07-25-2018, 04:43 AM -
Needed!!! Donated 4 Stroke O/b For Our 4 Stroke O/b Toss!!
By Instigator in forum General Boating DiscussionReplies: 19Last Post: 03-20-2003, 01:49 PM -
Comparison photo's Merc 225 4-stroke and Yamaha 225 4-stroke
By AlaskaStreamin in forum General Boating DiscussionReplies: 17Last Post: 11-08-2002, 11:10 PM
