Results 31 to 35 of 35
11-20-2020, 01:03 PM #31Member
- Jun 2020
- southeast GA
- 95
- 70
- 11
- 10
- 60
never had more than 2amp charge rate on that ecu what voltage when running vs not running im gonna check some ground wire this weekend
11-20-2020, 01:16 PM #32The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...yes, perfect grounds are important on anything thats efi. direct grounds and chassis/system grounds. its actually the very first thing that should be looked at thoroughly when diagnosing an issue.
tangerine386 thanked for this post
11-20-2020, 05:22 PM #335000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
Are both ECU's you've tried A17's? Try a box meant for a 260.... Or post a picture of the ECU your using. A17 should be all black with an embossed EFI on the front which is meant for a laser injection set up, not crankcase injected.
roadkill636, tangerine386 thanked for this postroadkill636 liked this post
11-20-2020, 07:23 PM #34
For the hundredth time: why not fix the fuel pressure, first and foremost?? The regulator is downstream (ie located on the return side) of the fuel rail, and controls pressure by releasing fuel back to the tank.
So, if you’re seeing 55psi ANYWHERE on the inlet side of the rail (or anywhere between the pump outlet and the regulator), then that’s the pressure the injectors are seeing!
11-21-2020, 12:00 PM #355000 RPM
- May 2019
- Sandy run SC
- 118
- 10
- 37
tangerine386 thanked for this postCI STV liked this post
v4 bogging at low end
By delawarerick in forum Technical DiscussionReplies: 14Last Post: 09-19-2018, 06:12 PM -
Mercury Tech: Bogging
By FisherBoats in forum Technical DiscussionReplies: 7Last Post: 07-26-2011, 12:43 PM -
Bogging xp 150
By Richie R in forum Technical DiscussionReplies: 6Last Post: 08-17-2006, 02:22 PM -
Still Having Bogging Problem On 2.5 Efi
By liberatorx2 in forum Technical DiscussionReplies: 9Last Post: 08-29-2002, 01:46 PM
