Results 16 to 30 of 35
11-18-2020, 11:12 AM #16Member
- Jun 2020
- southeast GA
- 95
- 70
- 11
- 10
- 60
my reg is in stock location my pressure is 55lbs before its regulated and it is a gold 39lb reg however its not a bosch it a aftermarket copy 30$ so maybe not working correct but why would it run great at first then act up is what confusing
11-18-2020, 12:17 PM #17
Did you do something to the regular to get it up to 55#s? Smash the spring? Is it pre set or adjustable?
tangerine386 thanked for this post
11-18-2020, 04:24 PM #185000 RPM
- May 2019
- Sandy run SC
- 118
- 10
- 37
As stated earlier it may run fine at first then the ECU reads to much fuel pressure and goes fat ! correct the fuel pressure problem and go from their . As you keep saying the cheap regulator my be the problem but you want know until you swap it out , but the bottom line is you need 39psi at the injectors not 55psi .
tangerine386 thanked for this postCI STV liked this post
11-18-2020, 04:39 PM #19
Does this motor still have the TPI switch on? a '93 should have come with one.
is gone
11-18-2020, 05:45 PM #20
Also you have Promax A17 ecu with crank case injectors. There could be a problem here. What injectors do you have?
11-19-2020, 07:52 AM #21Member
- Jun 2020
- southeast GA
- 95
- 70
- 11
- 10
- 60
yes does have throttle position box on it stock injecters this was a running motor that would push the boat into 90s the motor sat for five years could the old ecu be marked a17 and have somthing else in it it did same thing with old ecu fuel pump and old reg changed all to new still does it also that is correct ecu according to parts diagram od181275 model 93os 1925241nh L model
11-19-2020, 08:04 AM #22
Did you buy the regulator new or from someone else? Could someone have modified it? It’s quite easy to increase the pressure in those style of regulators by using a socket on top of it and tapping it to increase the tension on the spring. That’s an old trick the Buick GN guys used to do back in the late 80s early 90s to increase fuel pressure to forego a fuel injector upgrade.
11-19-2020, 09:39 AM #23Member
- Jun 2020
- southeast GA
- 95
- 70
- 11
- 10
- 60
brand new regulator but it was supposed to be a bosch replacment part the 39lb bosch was used in 70-80 volkswagens and jaguars when u cross ref part numbers i might have a bad ground wire somewhere messing with ecu as someone else has said
11-19-2020, 10:14 AM #245000 RPM
- May 2019
- Sandy run SC
- 118
- 10
- 37
11-19-2020, 06:39 PM #25
11-19-2020, 08:13 PM #26The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19217
- 3 Post(s)
...a fully charged healthy battery is critical with a 260 efi...
11-20-2020, 08:45 AM #27Member
- Jun 2020
- southeast GA
- 95
- 70
- 11
- 10
- 60
yes the box is two plug and tpi i run 2 battieries wired as one big battery 1000amp 650 amp always charge them night before i think im to the point where im just going to get rid of it whole thing or part out
11-20-2020, 10:13 AM #285000 RPM
- TN
- 470
- 7
when mine was doing that, it was the ecu.
it would go stupid rich.
put on an ACU and no more problems.
11-20-2020, 11:23 AM #29Member
- Jun 2020
- southeast GA
- 95
- 70
- 11
- 10
- 60
i did get a differant ecu but it may be bad too im think im done with it
11-20-2020, 12:42 PM #30The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19217
- 3 Post(s)
...turning on & off battery switches when charging can hurt ecu's sometimes also... in other words, they don't like voltage surges...
v4 bogging at low end
By delawarerick in forum Technical DiscussionReplies: 14Last Post: 09-19-2018, 06:12 PM -
Mercury Tech: Bogging
By FisherBoats in forum Technical DiscussionReplies: 7Last Post: 07-26-2011, 12:43 PM -
Bogging xp 150
By Richie R in forum Technical DiscussionReplies: 6Last Post: 08-17-2006, 02:22 PM -
Still Having Bogging Problem On 2.5 Efi
By liberatorx2 in forum Technical DiscussionReplies: 9Last Post: 08-29-2002, 01:46 PM
