Results 1 to 13 of 13
11-16-2020, 10:01 PM #15000 RPM
- Jun 2013
- Venezuela
- 190
- 13
Optimax Oil Reservoir Sensor Replacement
Is it possible to replace the oil sensor on a 225 Opti?
I heard from a friend that its a bitch to replace and I would have to get the whole tank replaced. I see the sensor on ebay for $20 and the tank for $150 so its a pretty big diff.
Anyone care to share their experience with this?
11-16-2020, 10:18 PM #2Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7149
- 3 Post(s)
Replace the tank. The float seems to get saturated if/when different oil brands get used. I have been down this trail twice now.
11-17-2020, 12:15 PM #3New Member
- Aug 2016
- texas
I have replaced the $20 sensor and it fixed the beeping. I was on the fence about buying a new tank again and figured for $20 it was worth the test.
11-17-2020, 12:25 PM #4Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
90+% of the time it's the float.
11-18-2020, 07:50 AM #5
Trying to fix them to where they will last with any consistency is a lot like building a ship in a bottle. If you can do that , bless ya man !
Me , I sometimes find debris in the bottle .. and also , just replace it and don't look back ..
11-18-2020, 07:53 AM #6Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
There is a "fix" but it involves glueing oily plastic. Sooooo...no.
11-21-2020, 10:28 AM #75000 RPM
- Jun 2013
- Venezuela
- 190
- 13
11-21-2020, 10:30 AM #85000 RPM
- Jun 2013
- Venezuela
- 190
- 13
11-23-2020, 03:35 PM #9New Member
- Aug 2016
- texas
11-23-2020, 03:40 PM #10Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
It's usually the float. I saw guy on u-tube take the tank apart, fix the float with copper wire and glue it back together. Sketchy is the best description. You can just jump the 2 wires (blue/black) going to the tank and stop the beeping. BUT you have to make SURE the tank is being supplied with oil. I carry a jump wire on all my boats for this reason.
11-25-2020, 11:24 PM #11
Well, since it takes time to get the parts, best off fixing it with a whole new tank because if you get just the sensor, and that doesn't fix it, you'll be waiting longer for a whole tank that you could have already had.
If yu want to run it and you KNOW the tank is being replenished properly with oil, then unhook the wire to the sensor and use a paper clip to jump the terminals on the wire on the engine side of the connection. Keep a close eye on the tank to be sure it's staying full.
You can use the old sensor wire to make a jumper for in case it happens again. Just cut the wire from the sensor and tie the two wires together and you have a jumper you can just plug in.Last edited by flabum1017; 11-25-2020 at 11:26 PM.
11-30-2020, 07:44 PM #125000 RPM
- Jun 2013
- Venezuela
- 190
- 13
This is exactly what I've been hearing after asking around. Always the float.
Found the video you mentioned for anyone interested: https://www.youtube.com/watch?v=G8LWgGa7Kgg
It makes the problem very clear at least. I think the fix is worth a try but I got in touch with my long time outboard lower unit guru and he s ays he fixes these bad boys up no sweat so I'll go with that. Support your local gurus!
Thanks to everyone who replied. I hope this thread helps the next poor schmuck going through this
11-30-2020, 08:01 PM #13Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Carry a spare jug of oil on board for when the repaired tank leaks all the oil out. You can use it to get home. jm2cts
Need Booked Out - Repair on 2014 Jeep GC - Oil Pressure Sensor Replacement
By Stoker1 in forum The Scream And Fly LoungeReplies: 4Last Post: 07-11-2016, 05:54 PM -
Optimax Oil Reservoir Question
By Fish in forum Technical DiscussionReplies: 6Last Post: 03-24-2013, 07:08 AM -
Oil reservoir tank replacement
By Powerplay25 in forum Technical DiscussionReplies: 2Last Post: 06-14-2010, 02:53 PM -
Optimax Oil reservoir - possible contamination
By thalweg in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 09-08-2008, 08:06 PM -
Throttle Positioning Sensor- TPS setting/replacement?
By MikesXpress in forum Technical DiscussionReplies: 26Last Post: 02-05-2006, 07:38 AM
