Results 1 to 7 of 7
11-16-2020, 01:39 PM #1Member
- Dec 2010
- Denmark
- 98
- 9
Flo-Torq SSR, hub, 2 stroke vs 4 stroke
Hey guys,
I have just found out that Mercury has a new propeller Hub "Flo-Torq SSR".
https://mercurymarine.widencollectiv...b-761aba9e12ef
It sounds good to get a hub that makes the gear shift more smoot. And i thought thats what I need on my Merc 260HP outboard, which need to idle a bit higher than other standrad 2,5L V6 Merc. But I learned that it seams that it is not suitable for 2 strokes,,,,. My question is why?
Kind Regards, ThomasLast edited by A164; 11-17-2020 at 12:58 AM.
11-16-2020, 03:55 PM #26000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
I used them on several 2 strokes. Only problem is getting them out of your propeller/s. Will need a press or ar least a bottle jack and some make shift holding mechanism.
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
A164 liked this post
11-17-2020, 01:07 AM #3Member
- Dec 2010
- Denmark
- 98
- 9
Hey DangerNewb,
Did you use the "Flo-Torq SSR Solid"?
Or did you use the "Flo-Torq SSR"?
Merc says that Flo-Torq SSR only goes for up to 225hp!
Found this youtube link;
https://www.youtube.com/watch?v=tYHXhujcqUk
.Last edited by A164; 11-17-2020 at 10:47 AM.
11-17-2020, 01:47 AM #46000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
I used the Flo Torq SSR HD. Part 8M0101603. Mentions several motors with fat shaft up to 400 Verado. Finally sold mine with a prop since I wasn't shifting while running anyway and it was too hard to swap between props.
Blazer 650 Pro Tour
11-17-2020, 04:51 AM #5Team Member
- Lake Coochiching, Ontario
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
When I had a 225 Promax I liked the hub. Not perfect shifts but better. My 200XS idles at much lower rpm and does not need it. I paid someone to press one out of a prop
11-17-2020, 03:06 PM #6
If it's a 260 and running more than 24 pitch just start in gear your gears and shift dog will thank you.
11-17-2020, 03:22 PM #7Member
- Dec 2010
- Denmark
- 98
- 9
Hi Dave, I know and also do so, but sometimes it is necessery to shift gears in Harbor whithout stopping engine.
how to start your outboard on a stand [4-stroke & 2-stroke]
By noli in forum Technical DiscussionReplies: 0Last Post: 09-24-2020, 06:25 AM -
2 stroke to 4 stroke re-power on smaller hull
By miagonz85 in forum Technical DiscussionReplies: 2Last Post: 07-25-2018, 09:02 AM -
By miagonz85 in forum Props, Setup, and RiggingReplies: 1Last Post: 07-25-2018, 04:43 AM -
Correct Flo-Torq II hub kit for Suzuki 140 hp 4-stroke?
By Markus in forum Technical DiscussionReplies: 1Last Post: 11-11-2005, 12:34 PM -
Comparison photo's Merc 225 4-stroke and Yamaha 225 4-stroke
By AlaskaStreamin in forum General Boating DiscussionReplies: 17Last Post: 11-08-2002, 11:10 PM
