Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 43
    Plainville, CT
    Porting Timing for Torque
    Been reading a few things on porting and can't say I really understand it that well. From what I can tell it seems narrower carbs and more compression will add to low end torque. Also, it seems lower exhaust porting is probably good for low end torque.
    Anyone know which 2.5 engine is ported to favor low end torque? Namely, would it be the 135, 150, 175, 200, XR6, EFI, Optimax, ProXS, etc?
    May 2014
    Livingston, Louisiana
    In a nut shell on port timing, important factors are port duration on both intake and exhaust ports, and blowdown degrees ( amount of degrees from the point when exhaust port begins opening until the transfers/ intake open.) Both duration and blowdown degrees affect the rpm range where max power/ torque is achieved. Lower durations/ shorter ports make power at lower rpm while longer durations/ higher ports are needed to make power at higher rpms. Even more crucial on what rpm max power is achieved, or even if any power is made dependent on transfer duration is blowdown. Higher degrees of blowdown duration is needed to make power at higher rpms to allow proper scavanging/charging of cylinder at quicker piston speeds but at lower rpms will cause a loss of charge mixture out the exhaust killing low end power. Both durations and blowdown have to work hand in hand for an engine to be efficient at particular rpm.
  3. Thanks Glastron1987 thanked for this post
    Likes Glastron1987, phillnjack, Merc 2.5 liked this post
    Sep 2011
    maryland
    As to carbs, smaller carbs do help lower torque as well. When I was messing with carbs on my 150 crossflow, there was a significant difference in holeshot with 1-1/4 carbs versus the larger 5/16 or 3/8 carbs. But it also ran outta steam up top too with the smaller carbs.
  5. Thanks Glastron1987 thanked for this post
    Likes Glastron1987, phillnjack liked this post
    Plainville, CT
    Excellent explanation. So if I understand that correctly an engine with lower port duration and lower blowdown degrees would be the one I am asking about. Of the V6's, which ones come stock towards that end of the scale?
    May 2014
    In the 2.5 family the 150’s make good low rpm torque, EFI versions better and opti makes the best. The higher hp models like the 200 make more torque but at little higher rpm. The 150’s make great working motors because of this.
  8. Thanks Glastron1987 thanked for this post
    Florida Keys
    Xr6
    small chest, lowest port timing, longest tuner on the planet, and tiny venturis on the carbs....while still at 2.5L of displacement. They run good.
    '95 STV "The Blue Goose"
  10. Thanks Glastron1987 thanked for this post
    Likes Glastron1987, Smalltownbassin liked this post
  11. #7
    May 2001
    Hickory NC
    Another item not mentioned is the angles on the ports. The top roof angle on the intake ports also has an effect on where power is made.
  12. Thanks Glastron1987, keefallan thanked for this post
  13. #8
    Plainville, CT
    So being a skier and barefooter it sounds like a 150 carb, XR6, 150 EFI, or 150 Opti would probably be preferred over a 200 really?
  14. #9
    May 2014
    Quote Originally Posted by Glastron1987 View Post
    Kinda depends, the 200 will make more torque just doesn’t have as much right off idle and getting up. I’d guess somewhere around the 3000 rpm range things change and the 200 will begin making more power. So depends on propping and set up and what’s the most crucial rpm for ya which will work best for ya.
  15. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
  16. #10
    May 2014
    Personally a 3.0 opti would be the ticket, if it’s an option.
  17. Thanks Glastron1987 thanked for this post
  18. #11
    Plainville, CT
    Got it, makes sense, thanks.
  19. #12
    Plainville, CT
    Oh my, loads of torque on that one I'm sure.
  20. #13
    Sep 2017
    Ashland city tn
    Get a stock ee 200. Lower port timing and longer exhaust runners in chest , add long tuner should have great torque,maybe keep compression to 135ish
  21. Thanks Glastron1987 thanked for this post
  22. #14
    Plainville, CT
    Quote Originally Posted by Merc 2.5 View Post
    What I think you are saying is that the stock 200 EE has lowered port timing and longer exhaust runners in the chest already, but probably has a short tuner and that should be replaced with the longer one for maximized torque... and no need to cut heads?
  23. #15
    He said get an Etec/G2 lol
  24. Likes Glastron1987, keefallan liked this post
  1. porting
    By thomas t in forum Technical Discussion
    Last Post: 09-04-2020, 07:29 PM
  2. Replies: 19
    Last Post: 09-09-2015, 07:56 PM
  3. OMC 2 L porting
    By evilrude 1 in forum Technical Discussion
    Last Post: 02-22-2014, 08:50 PM
  4. How much torque tab and how (already have a TH marine torque tamer)
    By Mr. Demeanor in forum Props, Setup, and Rigging
    Last Post: 10-04-2010, 08:51 PM
  5. Question on Z porting VS. Bridge porting?
    By Riverracer280SS in forum General Boating Discussion
    Last Post: 09-05-2001, 08:52 AM
