Results 1 to 14 of 14
Thread: Does it right 300 pm reeds?
11-12-2020, 11:09 AM #1Member
- Feb 2018
- Russia
- 64
11-12-2020, 11:29 AM #2The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
11-12-2020, 11:30 AM #3The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
12-06-2020, 03:32 PM #4Member
- Feb 2018
- Russia
- 64
Nobody knows? I found in specification, that 6 pedal metal reeds must be on 300 pm on stock. My reeds are better?
12-06-2020, 04:11 PM #55000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
Capt.Insane-o liked this post
12-31-2020, 06:49 AM #65000 RPM
- Sep 2017
- Collingwood Ont. Canada
- 318
- 35
- 11
- 91
- 51
12-31-2020, 06:56 AM #7Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
The motor came with 6 petal steel reeds,you have Boyesen 2 stage ,we make 6 petal single stage...I think you'll like them...
12-31-2020, 06:39 PM #8
Chris's reeds are much better than the boysens.
phillnjack liked this post
01-01-2021, 06:26 AM #9
Hydrotec also has a version
https://shop.hydrotecmarine.com/prod...&categoryId=11
SUNKIST, phillnjack liked this post
01-01-2021, 11:22 AM #10Member
- Feb 2018
- Russia
- 64
If i replace 6 pedal cages to 5 pedal and install 5 pedal reeds , what i can get in performance? It's not so cheap in complex, because engine need to rebuild (bore cylinders, i lost compression)
01-02-2021, 09:07 AM #115000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
The juice ain't worth the squeeze. Just CC the 6 petals.
01-12-2021, 12:49 AM #12
can the same ccm reeds be used with cages that the rubber was stripped off?
1998 charger stv. 225 promax. -sold-
1993 22 talon. 2016 yamaha 200 SHO, nizpro tuned
01-12-2021, 02:13 AM #13
Yes.
01-12-2021, 07:45 AM #14Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
We now have a special cut reed for the rubber off cages,a little larger sealing area than the standard ones,same price,in stock,Chris
mistah_max, phillnjack thanked for this postphillnjack liked this post
is the rubber 4 petal reeds and block better then 5 petal boyseen reeds?
By camaro7081 in forum Technical DiscussionReplies: 18Last Post: 04-05-2022, 05:35 AM -
Mercury Tech: fiber reeds and steel reeds in same motor
By buzmacdowell in forum Technical DiscussionReplies: 4Last Post: 07-09-2011, 10:06 PM -
horizontal reeds v/s vertical reeds?
By david martin in forum Technical DiscussionReplies: 10Last Post: 12-04-2007, 06:09 AM -
BOYESEN REEDS VS LAND & SEA REEDS
By MrCougar in forum Technical DiscussionReplies: 1Last Post: 05-14-2001, 07:08 AM
