Results 1 to 12 of 12
Thread: 260 horn & box
    Sep 2020
    New York
    260 horn & box
    260 air horn and efi box. Pm me offer
    Attached Thumbnails Attached Thumbnails AB6230CF-FE2B-4CBB-B1FF-E838EF844B57.jpg   2921C2CB-9C79-46E8-8F5C-744BACEDBDE1.jpg   454C511B-52B7-46BF-889F-70F02D3DB2E0.jpg
    Shreveport, La.
    What chip?
    Sep 2020
    New York
    A15
    Sep 2020
    New York
    still available
    Sep 2020
    New York
    still available
    A15 was the first 2.5 EFI analog ECU.
    Jun 2004
    Pelican Lake, WI
    Sent you couple PM's
    Sep 2020
    New York
    I pm you back.need shipping info.thank you
    MANITOBA CANADA
    Is the efi box still for sale ? I have a 89 2.4 bridgeport needing new box , it won't run right on stock 2.4 ecu . Motor was ported .
    woody
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by woody View Post
    A 2.5 box won't run right either. How much was it ported...I would think a stock 2.4 box would be a lot closer curve than a 2.5, just saying. You may need a digital box that you can get into, or just richen up the stock 2.4 box.
    MANITOBA CANADA
    It's been at least 10 years since I had it going. Sent the box to CDI and was told it was fried , not repairable . Tried a stock 2.4 Bridgeport box and it wouldn't run without lots of throttle on . It's a Don Tucker build , not sure but looks like cut out as much as one could . The motor did run well before the ecu died .
    Thanks , I will try a Brucato .
    woody
  12. #12
    Sep 2020
    New York
    horn is not available.the box is available.i have a 2.4 horn if needed.
  1. I'm not getting the warning horn test beep. Question about testing horn.
    By Bumblebeeman in forum Technical Discussion
    Last Post: 04-03-2020, 10:51 AM
  2. Mercury Tech: oil horn
    By goingtoslow in forum Technical Discussion
    Last Post: 03-08-2009, 07:56 AM
  3. 2.4EFI horn vs. 2.5EFI horn
    By STV_Keith in forum Technical Discussion
    Last Post: 01-25-2005, 09:04 PM
  4. what do u think about this 2.5 horn?
    By wild drag racer in forum Technical Discussion
    Last Post: 02-24-2004, 03:10 PM
