Results 1 to 11 of 11
11-08-2020, 07:42 PM #1Member
- Apr 2017
- Iowa
- 42
- 14
K&D Marine Dynamometer Model 2000
I am lucky enough to come in possession of such a piece of equipment, but have no idea if they are still useful in the shop. Does anybody still use them to load test outboards? Thanks!
11-08-2020, 07:58 PM #2
I have one of them as well. The shop it came from used it to load test but I plan on building a completely self contained bench with it for break in. I live out in the country so exhaust out side will be no issue.
RockTeam Junk
11-09-2020, 07:57 AM #3
A friend tried to sell me his 20 yrs ago.
He didn’t like it and said it overheated the oil too fast.
Load testing would be the key.
The ones I’ve seen read PSI and no HP.
Dont think they’re repeatable either.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
11-09-2020, 08:29 AM #4Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
What you do is mod the arms and fit a load cell so it can direct read force. They could do with a bigger oil cooler when you are close to 300hp, thats for sure
11-09-2020, 08:46 AM #5Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
The 2000 is really not meant for the larger engines. I had a 4000 and which has a much bigger oil tank and cooler as well as a larger pump assembly. We still broke the pump several times until we went to a hydraulics shop and built our own. It was still working when we closed. Like mentioned reads PSI and not hp
11-09-2020, 09:06 AM #6Member
- Apr 2017
- Iowa
- 42
- 14
This shop mostly works on 6hp to 115's, with an occasional up to 150. He works on lots of 4-40 hp older Evinrude outboards. Being fresh water, there are still allot of 50's, 60's, and 70's outboards that get serviced.
You are right, Instigator, as it reads in PSI.
Looks like it may end up on Ebay!
11-09-2020, 10:14 AM #7
I have one as well. Decent for load testing smaller stuff. Lots of them out there. Reads PSI not HP. Saves a fair amount of time going to the lake for a water test. Higher HP applications would need the 4000. Can be a useful tool in the right hands. I know BoostPower uses one of the 4000s often on his sterndrive stuff. I'm not sure to what extent though.
www.InjectorService.com
Call/Text - 204-326-0390
11-09-2020, 10:54 AM #8Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Definitely a good tool
https://m.youtube.com/watch?v=OogokgD7t6g
Lean on #3
11-09-2020, 12:57 PM #9Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
11-09-2020, 01:14 PM #10
There is a chart available. It doesn't cover newer stupp or higher HP. I'm assuming if you had a ton of time you could plot it in comparison to actual rated HP if you knew those numbers as well. Who knows. IMO, if your doing any real tuning probably just getting a Dynomite would be your best bet, although they are 15x the price, and good luck finding them used.
11-09-2020, 01:18 PM #11Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
In that video link, the marina has many dyno runs posted, he references a table of specs in some, wondered how complete the list is.
They also had a 4000 for-sale
Marine Dynamometer 2000
By rcmracing in forum Misc. Parts and AccessoriesReplies: 0Last Post: 06-25-2020, 08:36 AM -
2000 Model A30 ECU swap to PM A17?
By TheRickster in forum Technical DiscussionReplies: 13Last Post: 09-29-2013, 09:23 PM -
Mercury Tech: 2000 Model 225EFI
By Purvinator in forum Technical DiscussionReplies: 1Last Post: 02-28-2010, 09:28 AM
