Results 1 to 6 of 6
Thread: Cav Plate Foil
    Jul 2007
    Hamilton Ohio
    Cav Plate Foil
    99 Merc 175 EFI, If using a Cav Plate Foil like the "BMAN FOIL" and having hyd. steering, torque tab on your skeg is it still necessary to run the OEM trim tab under the cav plate ? I'm think'n no, but I'm no expert...................
    Gary
    Growing old is inevitable, growing up is optional.......
    North Tonawanda, NY
    I've run my last two Merc 150s with a skeg mounted torque tab and a cav plate foil. Both motors came from the factory with the flat cav plate anode- no fin, and both run just fine like this. My local Merc dealer has 3 different anodes in stock- one has the fin located such that it will hit many high rake props, a so-called "Offshore Tab" plate where the fin is offset to the rear such that it won't hit the prop, and the plain flat plate. My motors are mounted high enough such that the fin on the anode plate won't do anything at mid-range and higher speeds. The skeg mounted torque tab does a great job so that you don't really need the fin on the cav plate.
    Doug
  3. Likes phillnjack liked this post
    We always sawed the fin off the anode and ran the "torque tamers" on the skeg.
  5. Likes phillnjack liked this post
    Put your heel all the way to the bottom to measure for shoe size?
    Jul 2007
    Hamilton Ohio
    Thanks all !
    Gary
  8. Likes phillnjack liked this post
    Tab on the skeg makes the anode type fin redundant.
  1. Eagle One Drag Plate Foil
    By lance in forum Misc. Parts and Accessories
    Last Post: 08-01-2018, 11:54 AM
  2. Drag Plate/Foil
    By SouthernComfort in forum Misc. Parts and Accessories
    Last Post: 01-30-2015, 09:21 PM
