Results 1 to 3 of 3
Thread: Mod VP Lower Unit
11-02-2020, 07:54 PM #1
Mod VP Lower Unit
Is the Mod VP gearcase housing with the water intake just above the nosecone the same (i.e. interchangeable) as the Alpha SS housing? I have a NOS one and cannot find the number on it.
18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
11-02-2020, 08:17 PM #2
Sort of. You need to plug the transfer hole with a set screw.
99fxst99 thanked for this post
11-02-2020, 10:09 PM #3The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
...the capt. is refering to the oil passage hole in the top of the housing that allowed common outdrive oil to transfer from the upper drive to the lower gearcase when used on the alpha SS outdrive. never forget...when mercruiser sent me the first alpha SS unit(s) included in the new 454 magnum engine packages for install in some new 22 velocity's. those oil passage transfer holes in the gearcase housings were not drilled. yeah, had to replace those drives after testing...
99fxst99 thanked for this postDave Strong, Capt.Insane-o liked this post
Looking for a lower unit for 1985 evinrude v6, have blackmax lower to sell or trade
By tfmech in forum Lower UnitsReplies: 7Last Post: 02-20-2016, 01:34 PM -
mercury quicksilver lower unit vs tourqmaster lower unit
By jshotts in forum General Boating DiscussionReplies: 3Last Post: 01-26-2015, 01:23 PM -
Lower unit help 2007 115hp mercury can not find neutral,reverse with lower off
By pinetar in forum Technical DiscussionReplies: 0Last Post: 07-15-2014, 02:50 PM -
Mercury Tech: 2.4, 2.5 liter fishing lower unit into a 3.0 torque master lower unit
By cactusth in forum Technical DiscussionReplies: 3Last Post: 08-12-2011, 09:51 PM
