Results 1 to 9 of 9
Thread: CLE flush kit on sportmaster
10-31-2020, 04:27 PM #1
I have used my old cle flush kit on my sportmaster lu, with a little duct tape. Is there any problem with doing this or should I buy a sportmaster kit.
1986 cougar mtr 21
2003 supra launch ssv
10-31-2020, 04:51 PM #2
As long as your making water pressure, you're fine.
10-31-2020, 04:55 PM #3
As long as you don't mind cleaning duct tape residue off your junk and you have water pressure that way it's working...
There's a guy "marineengineflushers" I think on FB that sells all the different specific adapters for your lower, I'd probably just do that. What's the cost of the flusher adapter to the cost of a powerhead?Josh Peterson
Da Bull liked this post
11-01-2020, 04:53 AM #4
I use a 3Wx4Lx3deep tank from Tractor Supply and that way I know my water pump is picking up correctly.
11-01-2020, 06:10 AM #5
11-01-2020, 10:32 AM #6
Get a hose, a few small pieces of tubing that fit in the lower, epoxy,a couple hose clamp some heat shrink and a bungee cord and make one.. I made a bunch that way and they work really...it takes a little bit longer to setup but get the best water pressure..I'm looking for a pic/video of it on the motor.
I bought a couple of those marineflushers thought it would be easier to setup but. I can say the ones I bought sucked didn't work well enough to get water pressureLast edited by mrichartz; 11-01-2020 at 10:41 AM.
'84 Checkmate Convincor
11-01-2020, 10:36 AM #7
11-01-2020, 10:39 AM #86000 RPM
- Aug 2015
- Southeast
- 1,058
- 134
- 79
- 48
- 614
Epoxy 3 small tubes in a female hose end. Attach to hose.
Jam the tubes into the pick up holes. Tight fit so it stays in place. Cost about $2. Works on every lower ive ever had.Bullet CC w/ 225 Promax - Sold
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
11-01-2020, 11:46 AM #9
Sportmaster flush kit.
By moomba in forum Misc. Parts and AccessoriesReplies: 2Last Post: 10-03-2016, 04:05 PM
