Page 3 of 3 FirstFirst 1 2 3
Results 31 to 32 of 32
  1. #31
    Quote Originally Posted by Whaaaaat View Post
    How often you go cruising with your test wheel? What kind of numbers you put up with that thing?
    You want without turbulence, leave it in neutral and spin the rpm. Pump on its own without forced input.
    The capabilities of the pump through the pickups without help. It's been said it's holding back flow at high speed, it's been said too much pressure is not wanted , so start with the baseline of the pump capability through the rpm range.
    Bet the pump produces enough stand alone for the outboard through the entire range.
  2. #32
    Feb 2014
    Missouri
    With or without the popet s open
  1. salt water outboard
    By allboutspeed in forum Technical Discussion
    Last Post: 05-11-2009, 03:58 PM
  2. This would be fun!!!!! Shallow water drive outboard!
    By The Big Al in forum General Boating Discussion
    Last Post: 01-19-2007, 01:28 PM
  3. water pump in outboard
    By Carsen in forum Technical Discussion
    Last Post: 04-26-2003, 03:40 PM
