Results 1 to 15 of 32
10-29-2020, 05:20 PM #15000 RPM
- Mar 2020
- netherlands
- 163
- 14
How much water does a outboard use?
Hey! I was wondering, how much water does an outboard suck up at full throttle?
Is it possible to calculate it? Im just curious.
Is it: the capacity of all the chambers of the impeller × rpm?
How large would the capacity of a 115hp 2 stroke be?
10-30-2020, 07:15 AM #2
Damn dude, you must be bored.
RockTeam Junk
TEXAS20225, InjectorService, mrichartz, SS Minnow, Capt.Insane-o, rgsauger, tnelsmn, KIRCHNER, Glasstream15 liked this post
10-30-2020, 07:33 AM #3The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
10-30-2020, 03:55 PM #4
Just carry 4 barrels of good clean distilled water on your boat. And that should be enough for about 1 hour of full throttle
SS Minnow liked this post
10-30-2020, 05:45 PM #5
I got 5 acres needing weeded...
10-30-2020, 06:09 PM #6Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
10-30-2020, 06:10 PM #7
Hahahahahahahahhahahahahahahahhhahahhaaaaahhahahhhhh
10-30-2020, 07:12 PM #8The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
10-30-2020, 09:20 PM #9
After the first case of beer I forgot what he was asking
10-30-2020, 09:29 PM #10
Sorry killer I just could not resist. How much wood could a wood chuck chuck if a wood chuck could chuck wood.
10-30-2020, 11:13 PM #11Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Depends on which 115 l6.... or L4.....different h2o pumps.....Then the offset of pump housing. Then if ya have a restriction at the outlet......
racervboat liked this post
10-30-2020, 11:50 PM #12Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
there is a MCM service bulletin for 1 drives, showing gear ratio and free flow volumes so for a 47-89984 you can work it out ish
keefallan liked this post
10-31-2020, 05:02 AM #13Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
Killer, please dont be offended by the funny comment(s). It was all meant in fun. Its just an offbeat question. And truthfully, I cant answer that question for you. Please dont stop asking questions because of us. The same guys that make jokes will also be the same guys that give out great information when you need it.
10-31-2020, 11:04 AM #14
Its a very valid and good question, as I like a few others have often though about an external electrical water pump to feed the motors.
one way to find out would be to put a drill on a drive shaft and see just how quick you empty a certain amount of water in say 3 minutes. BUT you have to remember its not the amount a motor actually uses, the adaptor chucks out any excess water that the motor dont need and dumps that into the mid section..... so what the motor consumes will be very different to how much the water pump pushes out... I would think you dump out more than you consume by a long way..
David - WI, keefallan liked this post
10-31-2020, 11:30 AM #155000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
I think once your up to speed, especially the speeds some of us see. The water pump is actually limiting flow. If it wasn't for idle time I doubt a water pump would be necessary. Someone better at math than me should be able to get close just by knowing the inlet area × pressure.
Pressure would be a factor of speed. That should give an idea of how much water your passing, how much you actually need, would get a lot more complicated
David - WI liked this post
salt water outboard
By allboutspeed in forum Technical DiscussionReplies: 2Last Post: 05-11-2009, 03:58 PM -
This would be fun!!!!! Shallow water drive outboard!
By The Big Al in forum General Boating DiscussionReplies: 28Last Post: 01-19-2007, 01:28 PM -
water pump in outboard
By Carsen in forum Technical DiscussionReplies: 2Last Post: 04-26-2003, 03:40 PM
